I’m trying to create support for our boards for BalenaOS, so I’m following the instructions here:
I’m comfortable working with Yocto/OE as I’m the maintainer for our BSPs.
Having created all these files and repos, I attempted to start my build with “barys” as instructed. However, the tool refuses to run and only outputs this cryptic error:
$ ./balena-yocto-scripts/build/barys
Building JSON manifest…
/…/balena-topic/balena-yocto-scripts/build/node_modules/@resin.io/device-types/build.js:26
throw new Error("Ignored " + typeDefinition.slug + “: " + field + " is not set”);
Error: Ignored tdkzu6: state is not set
at Object.module.exports [as buildManifest] (/home/mike/projects/balena-topic/balena-yocto-scripts/build/node_modules/@resin.io/device-types/build.js:26:17)
at [stdin]:5:28
at ContextifyScript.Script.runInThisContext (vm.js:50:33)
at Object.runInThisContext (vm.js:139:38)
at Object. ([stdin]-wrapper:6:22)
at Module._compile (module.js:652:30)
at evalScript (bootstrap_node.js:463:27)
at ReadStream. (bootstrap_node.js:234:15)
at emitNone (events.js:111:20)
at ReadStream.emit (events.js:208:7)
at endReadableNT (_stream_readable.js:1064:12)
at _combinedTickCallback (internal/process/next_tick.js:138:11)
at process._tickCallback (internal/process/next_tick.js:180:9)
/…/balena-topic/balena-yocto-scripts/build/build-device-type-json.sh: ERROR - Please check your nodejs installation. The ‘nodejs’ binary did not generate a proper .json.
[000000001][ERROR]Could not generate .json file(s).
I added an entry “state: ‘released’” to the “coffee” file, but that didn’t make any difference.
It is worth comparing the contents of your coffee file to the examples in our balena-raspberrypi repository to check that you have the basics correct. If your problems still persist after this then please feel free to post your coffee file here so that we can review it.
Using the plain vanilla bitbake development flow, I got pretty far compiling the image. Only issue is with your “kernel-modules-headers.bb” recipe, it bails out with this cryptic message:
Hmm, only issue left now is that balena-image wants to install some initramfs package which clashes with ther kernel itself:
* check_data_file_clashes: Package kernel-image-image-4.19.0-xilinx-v2019.2 wants to install file /.../build/tmp/work/tdkzu6-poky-linux/balena-image/1.0-r0/rootfs/boot/Image
But that file is already provided by package * kernel-image-initramfs
The boards do not need any initramfs for booting. Looks like it’s the DISTRO that forces this initramfs stuff, is this something that’s required for BalenaOS?
Ah, the docs above said I had to inherit kernel-balena
but that class doesn’t exist anywhere. From the raspberrypi repo one glorks that the proper incantation is: inherit kernel-resin
Almost there. What’s the “json” file it’s looking for? I can’t find anything like that in the rpi repo, maybe it’s something that brays would have generated?
However, I have never run into this exact issue when doing a build, so I can’t say with certainty what is causing your failure. Do you get the same issue/error when running a build on a “regular” repo or supported device type. For example, if you clone and build the Raspberry Pi, does it also crash?
What is best way to solve this?
Is it possible to patch kernel-modules-headers.bb or should I create a kernel-modules-headers.bbappend that is only overriding the modified do_compile() snipet?
Hey @milo, the reason your json file is missing is due to these logs
Building JSON manifest...
/.../balena-topic/balena-yocto-scripts/build/node_modules/@resin.io/device-types/build.js:26
throw new Error("Ignored " + typeDefinition.slug + ": " + field + " is not set");
You need to ensure the *.coffee files in the root of your project have all the required fields, including the slug as mentioned above.
