Hi!
I’m trying to port balena to a custom BSP for Asus Tinkerboard S. I know, that there is already an official balena image and project. This is for learning purposes how to adapt on another BSP.
I followed the instructions in https://www.balena.io/os/docs/custom-build/ and created the files accordingly. This shows the tree of meta-balena-rockchip:
├── conf
│ ├── layer.conf
│ ├── machine
│ │ └── tinkerboard.conf
│ └── samples
│ ├── bblayers.conf.sample
│ └── local.conf.sample
├── recipes-bsp
│ └── bootfiles
├── recipes-containers
│ └── docker-disk
│ └── resin-supervisor.bbappend
├── recipes-core
│ └── images
│ └── resin-image.bbappend
├── recipes-kernel
│ └── linux
│ ├── linux-rockchip
│ └── linux-rockchip_4.4.bbappend
└── recipes-support
└── balena-init
├── files
└── resin-init-board.bbappend
This is the BSP i use for tinkerboard S: https://github.com/JeffyCN/meta-rockchip
This is my conf/machine/tinkerboard.conf
#@TYPE: Machine
##@NAME: tinkerboard
##@DESCRIPTION: Machine configuration for the Asus Tinkerboard S
MACHINEOVERRIDES = "rockchip-rk3288-evb:${MACHINE}"
include conf/machine/rockchip-rk3288-evb.conf
This is my conf/layer.conf
BBPATH .= ":${LAYERDIR}"
BBFILES += "${LAYERDIR}/recipes-*/*/*.bb \
${LAYERDIR}/recipes-*/*/*.bbappend"
BBFILE_COLLECTIONS += "balena-rockchip"
BBFILE_PATTERN_balena-rockchip := "^${LAYERDIR}/"
BBFILE_PRIORITY_balena-rockchip = "1337"
But i get the following errors:
./barys
Building JSON manifest...
npm WARN deprecated coffee-script@1.10.0: CoffeeScript on NPM has moved to "coffeescript" (no hyphen)
added 3 packages from 4 contributors and audited 3 packages in 2.14s
found 0 vulnerabilities
...Done
You had no conf/local.conf file. This configuration file has therefore been
created for you with some default values. You may wish to edit it to, for
example, select a different MACHINE (target hardware). See conf/local.conf
for more information as common configuration options are commented.
You had no conf/bblayers.conf file. This configuration file has therefore been
created for you with some default values. To add additional metadata layers
into your configuration please add entries to conf/bblayers.conf.
The Yocto Project has extensive documentation about OE including a reference
manual which can be found at:
http://yoctoproject.org/documentation
For more information about OpenEmbedded see their website:
http://www.openembedded.org/
_____ _ _____ ____
| __ \ (_) / _ \ / ___|
| |__) |___ ___ _ _ __ | | | || (___
| _ // _ \/ __| | '_ \ | | | | \___ \
| | \ \ __/\__ \ | | | || |_| | ___) |
|_| \_\___||___/_|_| |_|\_____/ |____/
Resin specific images available:
balena-image
Asus Tinkerboard S : $ MACHINE=tinkerboard bitbake balena-image
[000000003][LOG]BalenaOS build initialized in directory: build.
[000000003][LOG]Run build for tinkerboard: MACHINE=tinkerboard bitbake balena-image
[000000003][LOG]This might take a while ...
WARNING: Layer balena-rockchip should set LAYERSERIES_COMPAT_balena-rockchip in its conf/layer.conf file to list the core layer names it is compatible with.
Parsing recipes: 100% |########################################################################################################################| Time: 0:00:49
Parsing of 2178 .bb files complete (0 cached, 2178 parsed). 3155 targets, 313 skipped, 0 masked, 0 errors.
ERROR: Nothing PROVIDES 'balena-image'. Close matches:
balena-native
Summary: There were 2 WARNING messages shown.
Summary: There was 1 ERROR message shown, returning a non-zero exit code.
[000000054][LOG]Build for tinkerboard failed. Check failed log in build/tmp/log/cooker/tinkerboard .
[000000054][LOG]If build for tinkerboard succeeded, final image should have been generated here:
[000000054][LOG] build/tmp/deploy/images/tinkerboard/balena-image-tinkerboard.balena-img
[000000054][LOG]Done.
Can anyone support me on this?
Edit: Never mind, i found it out. The bitbake target in the coffee file should be named resin-image instead of balena-image and resinos-img instead of balenaos-img.
There are some real naming issues here between resin and balena
