UDPATE: I just unplugged the wired connection and then the ping through the wlan0 interface began to work after around 5 mins which leads me to assume that this is something on how the networking on resinos is setup.
Any leads on how to debug this would be much appreciated!
hey @lekkas thanks for checking in. I’ve figured out under what circumstances the issue occurs, but unfortunately haven’t figured out how to solve it.
If both eth0 and wlan0 are on the same range (10.10.10.x for example) then I have connectivity over both interfaces but if they are on a different range (10.10.10.x and 10.40.0.x like below) then I only have connectivity over one interface.
I am guessing I am misunderstanding some fundamental networking concepts in linux but I would really appreciate any ideas on to how to go about solving this as the main requirement of our project is to have the ability to run different diagnostic tests over both interfaces (which right now we cannot do unless they are on the same range, usually not the case).
root@4c28d5c:~# ifconfig eth0
eth0 Link encap:Ethernet HWaddr EE:50:44:83:61:85
inet addr:10.10.10.7 Bcast:10.10.10.255 Mask:255.255.255.0
inet6 addr: fe80::1d24:6c68:d093:410f%1995591680/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:60104523 errors:1 dropped:0 overruns:0 frame:1
TX packets:47511150 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:3981703426 (3.7 GiB) TX bytes:2086629929 (1.9 GiB)
root@4c28d5c:~# ping google.com -I 10.10.10.7 -c 3
PING google.com (173.194.219.100) from 10.10.10.7: 56 data bytes
64 bytes from 173.194.219.100: seq=0 ttl=43 time=105.181 ms
64 bytes from 173.194.219.100: seq=1 ttl=43 time=63.390 ms
64 bytes from 173.194.219.100: seq=2 ttl=43 time=114.697 ms
--- google.com ping statistics ---
3 packets transmitted, 3 packets received, 0% packet loss
round-trip min/avg/max = 63.390/94.422/114.697 ms
root@4c28d5c:~# ifconfig wlan0
wlan0 Link encap:Ethernet HWaddr B8:27:EB:62:C6:C2
inet addr:10.40.0.63 Bcast:10.40.0.255 Mask:255.255.255.0
inet6 addr: fe80::dead:9370:aeb4:4620%1995456512/64 Scope:Link
RX packets:781 errors:0 dropped:0 overruns:0 frame:0
TX packets:664 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:122403 (119.5 KiB) TX bytes:94850 (92.6 KiB)
root@4c28d5c:~# ping google.com -I 10.40.0.63 -c 3
PING google.com (173.194.219.113) from 10.40.0.63: 56 data bytes
3 packets transmitted, 0 packets received, 100% packet loss
root@4c28d5c:~# ip route | grep default
default via 10.10.10.1 dev eth0 metric 100
default via 10.40.0.1 dev wlan0 metric 600
Hi, sorry for following up on this so late. I am not familiar with the specifics of this type of router, but it looks like the router’s configuration may be wrong. Home routers usually provide a single subnet for both Ethernet and WiFi. This is an Enterprise router, so I assume it has the ability to provide two networks - one for Ethernet and one for WiFi. I assume configuration is done through DHCP for the WiFi network, so I exclude the option that you did not provide correct gateway address. If the router is running Linux (quite possibly so) you may connect to it through SSH or Telnet and check NAT settings, debug logs, etc. for both of those subnets.
Similar situation would be RPi to be connected to two routers at the same time. If both routers have Internet connectivity, the google ping will succeed through both interfaces.
