We’ve got a bunch of questions at resin about doing staged roll-out, when only a part of the fleet is updated, while the rest is kept back, and then increasing the deployment to the remaining devices in stages. There’s no official tool for that, but we were saying that it is entirely doable with update locking + API-triggered updates in a script. Took today’s Friday Hack time to actually write a proof of concept updater script for exactly this, so now we can put our code where our mouth is.
The source is available at resin-io-playground/resin-stageddeploy.
What it does is that it takes an APP_ID, and either a number (how many devices to update) or a percentage (what fraction of the fleet to update). Then it will check for eligible devices (ie. not updated yet, online, running an application, not provisioning), and triggers an update on a random subset of them up to the specified number of devices.
Install the dependencies for example by running pip install -r requirements.txt in the source directory.
$./stageddeploy.py --help
Usage: stageddeploy.py [OPTIONS] APP_ID
Helper script for staged roll-out for application updates on resin.io
Call it with a numerical APP_ID, and one of a number of devices (-n) or
percentage of fleet (-p) to trigger update on. If no number added, then
only query is run.
Only triggers online, idle, not updated, not provisioning devices.
Options:
-n, --number INTEGER Number of devices to trigger the update on
-p, --percent INTEGER Percentage of fleet to trigger the update on
-t, --token TEXT Resin.io auth token, can specify it with the TOKEN
env var as well [required]
-q, --quiet Toggles hiding process details
--help Show this message and exit.
Running an update:
$ ./stageddeploy.py 126746 -n 2
Logged in user: imrehg
App: MakerFaireDemo / Commit: ec6568e7153d1059e351bfd90caa48c0b70acf00
=== Devices ===
Device: B3 5577326 / Commit: 449385a / Online: True / Status: Idle
Device: B2 859eb5a / Commit: 4e7dedb / Online: True / Status: Idle
Device: A2 c3bcb2d / Commit: 4e7dedb / Online: True / Status: Idle
Device: B1 531a886 / Commit: ec6568e / Online: True / Status: Idle
Device: A1 4da60b4 / Commit: 4e7dedb / Online: True / Status: Idle
Device: A3 33adbe1 / Commit: 4e7dedb / Online: True / Status: Idle
Number of eligible devices: 5
Devices to update : 2
=== Updates ===
Updating: B2 859eb5a
Updating: A3 33adbe1
Of coures, it is just one way of doing it, and the Python SDK can also be replaced by the Node.js SDK, or even the Supervisor API, but at least there’s one version now that we can point to.
Let me know if you try it out, what do you think!
This is a proof-of-concept for me, the goal is to building things with the API. Everyone’s release method is different, and been asked a couple of times for “updating 10% of our devices” and similar questions, that’s why I made this format. The one-by-one confirmation is of course finer control.
