Ethernet, i’ve reset the entire network, it seems ok now.
but it makes little sense to me, since a device connected to the same switch was working just fine, same board type, same version (both os and app)
Hi there, what is the total amount of devices you use for testing? We highly recommend switching from the staging environment to the production BalenaCloud app, since there are no guarantees for the staging and it may well at any point be broken or even removed.
Hi there,
I wanted to circle back and mention that even if you are using the staging environment to test new OS images, you can typically use balena-cli's join and leave commands to move that device after provisioning back to the production balenaCloud. This is the workflow we heavily recommend, as staging can become unresponsive at any time. Moving back to production helps to eliminate variables and sources of confusion. You can read more about that process here: https://github.com/balena-io/balena-cli-advanced-masterclass#22-moving-devices-between-environments.
Please let us know if we can help in any way.
Hi there.
for some reason i still encounter issues of connectivity, we moved to production, i have 1 system that is Heartbeat only, although when i connect with our debug i can ping google and looks like its online.
root@7649a5d:~# journalctl --no-pager --no-hostname -n 200 -a -u "openvpn*"journalctl --no-pager --no-hostname -n 200 -a -u “openvpn*”
– Logs begin at Mon 2020-06-15 06:22:41 UTC, end at Mon 2020-06-15 06:33:48 UTC. –
Jun 15 06:28:35 openvpn[2433]: Mon Jun 15 06:28:35 2020 /sbin/ip addr del dev resin-vpn local 10.240.25.89 peer 52.4.252.97
Jun 15 06:28:35 openvpn[2433]: ip: RTNETLINK answers: Operation not permitted
Jun 15 06:28:35 openvpn[2433]: Mon Jun 15 06:28:35 2020 Linux ip addr del failed: external program exited with error status: 2
Jun 15 06:28:35 openvpn[2433]: Mon Jun 15 06:28:35 2020 /etc/openvpn-misc/downscript.sh resin-vpn 1500 1555 10.240.25.89 52.4.252.97 init
Jun 15 06:28:36 openvpn[2433]: Mon Jun 15 06:28:36 2020 ROUTE_GATEWAY 10.0.0.138/255.255.255.0 IFACE=eth0 HWADDR=f8:dc:7a:3e:3a:23
Jun 15 06:28:36 openvpn[2433]: Mon Jun 15 06:28:36 2020 ERROR: Cannot ioctl TUNSETIFF resin-vpn: Operation not permitted (errno=1)
Jun 15 06:28:36 openvpn[2433]: Mon Jun 15 06:28:36 2020 Exiting due to fatal error
Jun 15 06:28:36 systemd[1]: e[0;1;39me[0;1;31me[0;1;39mopenvpn.service: Main process exited, code=exited, status=1/FAILUREe[0m
Jun 15 06:28:36 systemd[1]: e[0;1;39me[0;1;31me[0;1;39mopenvpn.service: Failed with result ‘exit-code’.e[0m
Jun 15 06:28:46 openvpn[2573]: Mon Jun 15 06:28:46 2020 WARNING: file ‘/var/volatile/vpn-auth’ is group or others accessible
Jun 15 06:28:46 openvpn[2573]: Mon Jun 15 06:28:46 2020 OpenVPN 2.4.7 aarch64-poky-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTI
NFO] [AEAD] built on Apr 13 2020
Jun 15 06:28:46 openvpn[2573]: Mon Jun 15 06:28:46 2020 library versions: OpenSSL 1.0.2p 14 Aug 2018, LZO 2.10
Jun 15 06:28:46 openvpn[2573]: Mon Jun 15 06:28:46 2020 NOTE: the current --script-security setting may allow this configuration to call
user-defined scripts
Jun 15 06:28:46 openvpn[2573]: Mon Jun 15 06:28:46 2020 TCP/UDP: Preserving recently used remote address: [AF_INET]35.169.89.252:443
Jun 15 06:28:46 openvpn[2573]: Mon Jun 15 06:28:46 2020 Socket Buffers: R=[87380->87380] S=[16384->16384]
Jun 15 06:28:46 openvpn[2573]: Mon Jun 15 06:28:46 2020 Attempting to establish TCP connection with [AF_INET]35.169.89.252:443 [nonblock]
Jun 15 06:28:47 openvpn[2573]: Mon Jun 15 06:28:47 2020 TCP connection established with [AF_INET]35.169.89.252:443
Jun 15 06:28:47 openvpn[2573]: Mon Jun 15 06:28:47 2020 TCP_CLIENT link local: (not bound)
Jun 15 06:28:47 openvpn[2573]: Mon Jun 15 06:28:47 2020 TCP_CLIENT link remote: [AF_INET]35.169.89.252:443
Jun 15 06:28:47 openvpn[2573]: Mon Jun 15 06:28:47 2020 NOTE: UID/GID downgrade will be delayed because of --client, --pull, or --up-dela
y
Jun 15 06:28:47 openvpn[2573]: Mon Jun 15 06:28:47 2020 TLS: Initial packet from [AF_INET]35.169.89.252:443, sid=7958338a 3f223f77
Jun 15 06:28:47 openvpn[2573]: Mon Jun 15 06:28:47 2020 WARNING: this configuration may cache passwords in memory – use the auth-nocache
option to prevent this
Jun 15 06:28:48 openvpn[2573]: Mon Jun 15 06:28:48 2020 VERIFY OK: depth=1, C=AU, ST=Some-State, O=Internet Widgits Pty Ltd
Jun 15 06:28:48 openvpn[2573]: Mon Jun 15 06:28:48 2020 VERIFY KU OK
Jun 15 06:28:48 openvpn[2573]: Mon Jun 15 06:28:48 2020 Validating certificate extended key usage
Jun 15 06:28:48 openvpn[2573]: Mon Jun 15 06:28:48 2020 ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Serve
r Authentication
Jun 15 06:28:48 openvpn[2573]: Mon Jun 15 06:28:48 2020 VERIFY EKU OK
Jun 15 06:28:48 openvpn[2573]: Mon Jun 15 06:28:48 2020 VERIFY OK: depth=0, CN=vpn.balena-cloud.com
Jun 15 06:28:48 openvpn[2573]: Mon Jun 15 06:28:48 2020 Control Channel: TLSv1.2, cipher TLSv1/SSLv3 ECDHE-RSA-AES256-GCM-SHA384, 2048 bi
t RSA
Jun 15 06:28:48 openvpn[2573]: Mon Jun 15 06:28:48 2020 [vpn.balena-cloud.com] Peer Connection Initiated with [AF_INET]35.169.89.252:443
Jun 15 06:28:49 openvpn[2573]: Mon Jun 15 06:28:49 2020 SENT CONTROL [vpn.balena-cloud.com]: ‘PUSH_REQUEST’ (status=1)
Jun 15 06:28:49 openvpn[2573]: Mon Jun 15 06:28:49 2020 PUSH: Received control message: ‘PUSH_REPLY,sndbuf 0,rcvbuf 0,route 52.4.252.97,p
ing 10,ping-restart 60,socket-flags TCP_NODELAY,ifconfig 10.240.42.32 52.4.252.97,peer-id 0,cipher AES-256-GCM’
Jun 15 06:28:49 openvpn[2573]: Mon Jun 15 06:28:49 2020 OPTIONS IMPORT: timers and/or timeouts modified
Jun 15 06:28:49 openvpn[2573]: Mon Jun 15 06:28:49 2020 OPTIONS IMPORT: --sndbuf/–rcvbuf options modified
Jun 15 06:28:49 openvpn[2573]: Mon Jun 15 06:28:49 2020 Socket Buffers: R=[369920->369920] S=[87040->87040]
Jun 15 06:28:49 openvpn[2573]: Mon Jun 15 06:28:49 2020 OPTIONS IMPORT: --socket-flags option modified
Jun 15 06:28:49 openvpn[2573]: Mon Jun 15 06:28:49 2020 Socket flags: TCP_NODELAY=1 succeeded
Jun 15 06:28:49 openvpn[2573]: Mon Jun 15 06:28:49 2020 OPTIONS IMPORT: --ifconfig/up options modified
Jun 15 06:28:49 openvpn[2573]: Mon Jun 15 06:28:49 2020 OPTIONS IMPORT: route options modified
Jun 15 06:28:49 openvpn[2573]: Mon Jun 15 06:28:49 2020 OPTIONS IMPORT: peer-id set
Jun 15 06:28:49 openvpn[2573]: Mon Jun 15 06:28:49 2020 OPTIONS IMPORT: adjusting link_mtu to 1627
Jun 15 06:28:49 openvpn[2573]: Mon Jun 15 06:28:49 2020 OPTIONS IMPORT: data channel crypto options modified
Jun 15 06:28:49 openvpn[2573]: Mon Jun 15 06:28:49 2020 Data Channel: using negotiated cipher ‘AES-256-GCM’
Jun 15 06:28:49 openvpn[2573]: Mon Jun 15 06:28:49 2020 Outgoing Data Channel: Cipher ‘AES-256-GCM’ initialized with 256 bit key
Jun 15 06:28:49 openvpn[2573]: Mon Jun 15 06:28:49 2020 Incoming Data Channel: Cipher ‘AES-256-GCM’ initialized with 256 bit key
Jun 15 06:28:49 openvpn[2573]: Mon Jun 15 06:28:49 2020 ROUTE_GATEWAY 10.0.0.138/255.255.255.0 IFACE=eth0 HWADDR=f8:dc:7a:3e:3a:23
Jun 15 06:28:49 openvpn[2573]: Mon Jun 15 06:28:49 2020 TUN/TAP device resin-vpn opened
Jun 15 06:28:49 openvpn[2573]: Mon Jun 15 06:28:49 2020 TUN/TAP TX queue length set to 100
Jun 15 06:28:49 openvpn[2573]: Mon Jun 15 06:28:49 2020 /sbin/ip link set dev resin-vpn up mtu 1500
Jun 15 06:28:49 openvpn[2573]: Mon Jun 15 06:28:49 2020 /sbin/ip addr add dev resin-vpn local 10.240.42.32 peer 52.4.252.97
Jun 15 06:28:49 openvpn[2573]: Mon Jun 15 06:28:49 2020 /etc/openvpn-misc/upscript.sh resin-vpn 1500 1555 10.240.42.32 52.4.252.97 init
Jun 15 06:28:49 openvpn[2573]: resin-ntp-config: Found config.json in /mnt/boot/config.json .
Jun 15 06:28:49 openvpn[2573]: Mon Jun 15 06:28:49 2020 /sbin/ip route add 52.4.252.97/32 via 52.4.252.97
Jun 15 06:28:49 openvpn[2573]: ip: RTNETLINK answers: File exists
Jun 15 06:28:49 openvpn[2573]: Mon Jun 15 06:28:49 2020 ERROR: Linux route add command failed: external program exited with error status:
2
Jun 15 06:28:49 openvpn[2573]: Mon Jun 15 06:28:49 2020 GID set to openvpn
Jun 15 06:28:49 openvpn[2573]: Mon Jun 15 06:28:49 2020 UID set to openvpn
Jun 15 06:28:49 openvpn[2573]: Mon Jun 15 06:28:49 2020 Initialization Sequence Completed
Jun 15 06:29:49 openvpn[2573]: Mon Jun 15 06:29:49 2020 [vpn.balena-cloud.com] Inactivity timeout (–ping-restart), restarting
Jun 15 06:29:49 openvpn[2573]: Mon Jun 15 06:29:49 2020 /etc/openvpn-misc/downscript.sh resin-vpn 1500 1555 10.240.42.32 52.4.252.97 rest
art
Jun 15 06:29:49 openvpn[2573]: Mon Jun 15 06:29:49 2020 SIGUSR1[soft,ping-restart] received, process restarting
Jun 15 06:29:49 openvpn[2573]: Mon Jun 15 06:29:49 2020 Restart pause, 5 second(s)
Jun 15 06:29:54 openvpn[2573]: Mon Jun 15 06:29:54 2020 NOTE: the current --script-security setting may allow this configuration to call
Jun 15 06:29:54 openvpn[2573]: Mon Jun 15 06:29:54 2020 TCP/UDP: Preserving recently used remote address: [AF_INET]35.169.89.252:443
Jun 15 06:29:54 openvpn[2573]: Mon Jun 15 06:29:54 2020 Socket Buffers: R=[87380->87380] S=[16384->16384]
Jun 15 06:29:54 openvpn[2573]: Mon Jun 15 06:29:54 2020 Attempting to establish TCP connection with [AF_INET]35.169.89.252:443 [nonblock]
Jun 15 06:29:55 openvpn[2573]: Mon Jun 15 06:29:55 2020 TCP connection established with [AF_INET]35.169.89.252:443
Jun 15 06:29:55 openvpn[2573]: Mon Jun 15 06:29:55 2020 Socket flags: TCP_NODELAY=1 succeeded
Jun 15 06:29:55 openvpn[2573]: Mon Jun 15 06:29:55 2020 TCP_CLIENT link local: (not bound)
Jun 15 06:29:55 openvpn[2573]: Mon Jun 15 06:29:55 2020 TCP_CLIENT link remote: [AF_INET]35.169.89.252:443
Jun 15 06:29:56 openvpn[2573]: Mon Jun 15 06:29:56 2020 TLS: Initial packet from [AF_INET]35.169.89.252:443, sid=166dd919 439be626
Jun 15 06:29:56 openvpn[2573]: Mon Jun 15 06:29:56 2020 VERIFY OK: depth=1, C=AU, ST=Some-State, O=Internet Widgits Pty Ltd
Jun 15 06:29:56 openvpn[2573]: Mon Jun 15 06:29:56 2020 VERIFY KU OK
Jun 15 06:29:56 openvpn[2573]: Mon Jun 15 06:29:56 2020 Validating certificate extended key usage
Jun 15 06:29:56 openvpn[2573]: Mon Jun 15 06:29:56 2020 ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Serve
r Authentication
Jun 15 06:29:56 openvpn[2573]: Mon Jun 15 06:29:56 2020 VERIFY EKU OK
Jun 15 06:29:56 openvpn[2573]: Mon Jun 15 06:29:56 2020 VERIFY OK: depth=0, CN=vpn.balena-cloud.com
Jun 15 06:29:56 openvpn[2573]: Mon Jun 15 06:29:56 2020 Control Channel: TLSv1.2, cipher TLSv1/SSLv3 ECDHE-RSA-AES256-GCM-SHA384, 2048 bi
t RSA
Jun 15 06:29:56 openvpn[2573]: Mon Jun 15 06:29:56 2020 [vpn.balena-cloud.com] Peer Connection Initiated with [AF_INET]35.169.89.252:443
Jun 15 06:29:57 openvpn[2573]: Mon Jun 15 06:29:57 2020 SENT CONTROL [vpn.balena-cloud.com]: ‘PUSH_REQUEST’ (status=1)
Jun 15 06:29:57 openvpn[2573]: Mon Jun 15 06:29:57 2020 PUSH: Received control message: ‘PUSH_REPLY,sndbuf 0,rcvbuf 0,route 52.4.252.97,p
ing 10,ping-restart 60,socket-flags TCP_NODELAY,ifconfig 10.240.13.229 52.4.252.97,peer-id 0,cipher AES-256-GCM’
Jun 15 06:29:57 openvpn[2573]: Mon Jun 15 06:29:57 2020 OPTIONS IMPORT: timers and/or timeouts modified
Jun 15 06:29:57 openvpn[2573]: Mon Jun 15 06:29:57 2020 OPTIONS IMPORT: --sndbuf/–rcvbuf options modified
Jun 15 06:29:57 openvpn[2573]: Mon Jun 15 06:29:57 2020 Socket Buffers: R=[369920->369920] S=[87040->87040]
Jun 15 06:29:57 openvpn[2573]: Mon Jun 15 06:29:57 2020 OPTIONS IMPORT: --socket-flags option modified
Jun 15 06:29:57 openvpn[2573]: Mon Jun 15 06:29:57 2020 Socket flags: TCP_NODELAY=1 succeeded
Jun 15 06:29:57 openvpn[2573]: Mon Jun 15 06:29:57 2020 OPTIONS IMPORT: --ifconfig/up options modified
Jun 15 06:29:57 openvpn[2573]: Mon Jun 15 06:29:57 2020 OPTIONS IMPORT: route options modified
Jun 15 06:29:57 openvpn[2573]: Mon Jun 15 06:29:57 2020 OPTIONS IMPORT: peer-id set
Jun 15 06:29:57 openvpn[2573]: Mon Jun 15 06:29:57 2020 OPTIONS IMPORT: adjusting link_mtu to 1627
Jun 15 06:29:57 openvpn[2573]: Mon Jun 15 06:29:57 2020 OPTIONS IMPORT: data channel crypto options modified
Jun 15 06:29:57 openvpn[2573]: Mon Jun 15 06:29:57 2020 Data Channel: using negotiated cipher ‘AES-256-GCM’
Jun 15 06:29:57 openvpn[2573]: Mon Jun 15 06:29:57 2020 Outgoing Data Channel: Cipher ‘AES-256-GCM’ initialized with 256 bit key
Jun 15 06:29:57 openvpn[2573]: Mon Jun 15 06:29:57 2020 Incoming Data Channel: Cipher ‘AES-256-GCM’ initialized with 256 bit key
Jun 15 06:29:57 openvpn[2573]: Mon Jun 15 06:29:57 2020 Preserving previous TUN/TAP instance: resin-vpn
Jun 15 06:29:57 openvpn[2573]: Mon Jun 15 06:29:57 2020 /etc/openvpn-misc/upscript.sh resin-vpn 1500 1555 10.240.42.32 52.4.252.97 restar
t
Jun 15 06:29:57 openvpn[2573]: resin-ntp-config: Found config.json in /mnt/boot/config.json .
Jun 15 06:29:57 openvpn[2573]: Mon Jun 15 06:29:57 2020 NOTE: Pulled options changed on restart, will need to close and reopen TUN/TAP de
vice.
Jun 15 06:29:57 openvpn[2573]: Mon Jun 15 06:29:57 2020 Closing TUN/TAP interface
Jun 15 06:29:57 openvpn[2573]: Mon Jun 15 06:29:57 2020 /sbin/ip addr del dev resin-vpn local 10.240.42.32 peer 52.4.252.97
Jun 15 06:29:57 openvpn[2573]: ip: RTNETLINK answers: Operation not permitted
Jun 15 06:29:57 openvpn[2573]: Mon Jun 15 06:29:57 2020 Linux ip addr del failed: external program exited with error status: 2
Jun 15 06:29:57 openvpn[2573]: Mon Jun 15 06:29:57 2020 /etc/openvpn-misc/downscript.sh resin-vpn 1500 1555 10.240.42.32 52.4.252.97 init
Jun 15 06:29:58 openvpn[2573]: Mon Jun 15 06:29:58 2020 ROUTE_GATEWAY 10.0.0.138/255.255.255.0 IFACE=eth0 HWADDR=f8:dc:7a:3e:3a:23
Jun 15 06:29:58 openvpn[2573]: Mon Jun 15 06:29:58 2020 ERROR: Cannot ioctl TUNSETIFF resin-vpn: Operation not permitted (errno=1)
Jun 15 06:29:58 openvpn[2573]: Mon Jun 15 06:29:58 2020 Exiting due to fatal error
Jun 15 06:29:58 systemd[1]: e[0;1;39me[0;1;31me[0;1;39mopenvpn.service: Main process exited, code=exited, status=1/FAILUREe[0m
Jun 15 06:29:58 systemd[1]: e[0;1;39me[0;1;31me[0;1;39mopenvpn.service: Failed with result ‘exit-code’.e[0m
Jun 15 06:30:08 openvpn[2871]: Mon Jun 15 06:30:08 2020 WARNING: file ‘/var/volatile/vpn-auth’ is group or others accessible
Jun 15 06:30:08 openvpn[2871]: Mon Jun 15 06:30:08 2020 OpenVPN 2.4.7 aarch64-poky-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTI
Jun 15 06:30:08 openvpn[2871]: Mon Jun 15 06:30:08 2020 library versions: OpenSSL 1.0.2p 14 Aug 2018, LZO 2.10
Jun 15 06:30:08 openvpn[2871]: Mon Jun 15 06:30:08 2020 NOTE: the current --script-security setting may allow this configuration to call
Jun 15 06:30:08 openvpn[2871]: Mon Jun 15 06:30:08 2020 TCP/UDP: Preserving recently used remote address: [AF_INET]35.169.89.252:443
Jun 15 06:30:08 openvpn[2871]: Mon Jun 15 06:30:08 2020 Socket Buffers: R=[87380->87380] S=[16384->16384]
Jun 15 06:30:08 openvpn[2871]: Mon Jun 15 06:30:08 2020 Attempting to establish TCP connection with [AF_INET]35.169.89.252:443 [nonblock]
Jun 15 06:31:13 openvpn[2871]: Mon Jun 15 06:31:13 2020 TCP connection established with [AF_INET]35.169.89.252:443
Jun 15 06:31:13 openvpn[2871]: Mon Jun 15 06:31:13 2020 TCP_CLIENT link local: (not bound)
Jun 15 06:31:13 openvpn[2871]: Mon Jun 15 06:31:13 2020 TCP_CLIENT link remote: [AF_INET]35.169.89.252:443
Jun 15 06:31:13 openvpn[2871]: Mon Jun 15 06:31:13 2020 NOTE: UID/GID downgrade will be delayed because of --client, --pull, or --up-dela
y
Jun 15 06:31:14 openvpn[2871]: Mon Jun 15 06:31:14 2020 TLS: Initial packet from [AF_INET]35.169.89.252:443, sid=33721199 53dfce6d
Jun 15 06:31:14 openvpn[2871]: Mon Jun 15 06:31:14 2020 WARNING: this configuration may cache passwords in memory – use the auth-nocache
Jun 15 06:31:14 openvpn[2871]: Mon Jun 15 06:31:14 2020 VERIFY OK: depth=1, C=AU, ST=Some-State, O=Internet Widgits Pty Ltd
Jun 15 06:31:14 openvpn[2871]: Mon Jun 15 06:31:14 2020 VERIFY KU OK
Jun 15 06:31:14 openvpn[2871]: Mon Jun 15 06:31:14 2020 Validating certificate extended key usage
Jun 15 06:31:14 openvpn[2871]: Mon Jun 15 06:31:14 2020 ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Serve
r Authentication
Jun 15 06:31:14 openvpn[2871]: Mon Jun 15 06:31:14 2020 VERIFY EKU OK
Jun 15 06:31:14 openvpn[2871]: Mon Jun 15 06:31:14 2020 VERIFY OK: depth=0, CN=vpn.balena-cloud.com
Jun 15 06:31:15 openvpn[2871]: Mon Jun 15 06:31:15 2020 Control Channel: TLSv1.2, cipher TLSv1/SSLv3 ECDHE-RSA-AES256-GCM-SHA384, 2048 bi
t RSA
Jun 15 06:31:15 openvpn[2871]: Mon Jun 15 06:31:15 2020 [vpn.balena-cloud.com] Peer Connection Initiated with [AF_INET]35.169.89.252:443
Jun 15 06:31:16 openvpn[2871]: Mon Jun 15 06:31:16 2020 SENT CONTROL [vpn.balena-cloud.com]: ‘PUSH_REQUEST’ (status=1)
Jun 15 06:31:21 openvpn[2871]: Mon Jun 15 06:31:21 2020 SENT CONTROL [vpn.balena-cloud.com]: ‘PUSH_REQUEST’ (status=1)
Jun 15 06:31:26 openvpn[2871]: Mon Jun 15 06:31:26 2020 SENT CONTROL [vpn.balena-cloud.com]: ‘PUSH_REQUEST’ (status=1)
Jun 15 06:31:31 openvpn[2871]: Mon Jun 15 06:31:31 2020 SENT CONTROL [vpn.balena-cloud.com]: ‘PUSH_REQUEST’ (status=1)
Jun 15 06:31:36 openvpn[2871]: Mon Jun 15 06:31:36 2020 SENT CONTROL [vpn.balena-cloud.com]: ‘PUSH_REQUEST’ (status=1)
Jun 15 06:31:41 openvpn[2871]: Mon Jun 15 06:31:41 2020 SENT CONTROL [vpn.balena-cloud.com]: ‘PUSH_REQUEST’ (status=1)
Jun 15 06:31:46 openvpn[2871]: Mon Jun 15 06:31:46 2020 SENT CONTROL [vpn.balena-cloud.com]: ‘PUSH_REQUEST’ (status=1)
Jun 15 06:31:51 openvpn[2871]: Mon Jun 15 06:31:51 2020 SENT CONTROL [vpn.balena-cloud.com]: ‘PUSH_REQUEST’ (status=1)
Jun 15 06:31:56 openvpn[2871]: Mon Jun 15 06:31:56 2020 SENT CONTROL [vpn.balena-cloud.com]: ‘PUSH_REQUEST’ (status=1)
Jun 15 06:32:01 openvpn[2871]: Mon Jun 15 06:32:01 2020 SENT CONTROL [vpn.balena-cloud.com]: ‘PUSH_REQUEST’ (status=1)
Jun 15 06:32:06 openvpn[2871]: Mon Jun 15 06:32:06 2020 SENT CONTROL [vpn.balena-cloud.com]: ‘PUSH_REQUEST’ (status=1)
Jun 15 06:32:11 openvpn[2871]: Mon Jun 15 06:32:11 2020 SENT CONTROL [vpn.balena-cloud.com]: ‘PUSH_REQUEST’ (status=1)
Jun 15 06:32:16 openvpn[2871]: Mon Jun 15 06:32:16 2020 No reply from server after sending 12 push requests
Jun 15 06:32:16 openvpn[2871]: Mon Jun 15 06:32:16 2020 SIGUSR1[soft,no-push-reply] received, process restarting
Jun 15 06:32:16 openvpn[2871]: Mon Jun 15 06:32:16 2020 Restart pause, 5 second(s)
Jun 15 06:32:21 openvpn[2871]: Mon Jun 15 06:32:21 2020 NOTE: the current --script-security setting may allow this configuration to call
Jun 15 06:32:21 openvpn[2871]: Mon Jun 15 06:32:21 2020 TCP/UDP: Preserving recently used remote address: [AF_INET]35.169.76.143:443
Jun 15 06:32:21 openvpn[2871]: Mon Jun 15 06:32:21 2020 Socket Buffers: R=[87380->87380] S=[16384->16384]
Jun 15 06:32:21 openvpn[2871]: Mon Jun 15 06:32:21 2020 Attempting to establish TCP connection with [AF_INET]35.169.76.143:443 [nonblock]
Jun 15 06:32:22 openvpn[2871]: Mon Jun 15 06:32:22 2020 TCP connection established with [AF_INET]35.169.76.143:443
Jun 15 06:32:22 openvpn[2871]: Mon Jun 15 06:32:22 2020 TCP_CLIENT link local: (not bound)
Jun 15 06:32:22 openvpn[2871]: Mon Jun 15 06:32:22 2020 TCP_CLIENT link remote: [AF_INET]35.169.76.143:443
Jun 15 06:32:22 openvpn[2871]: Mon Jun 15 06:32:22 2020 TLS: Initial packet from [AF_INET]35.169.76.143:443, sid=7c403c46 d160e2ef
Jun 15 06:32:22 openvpn[2871]: Mon Jun 15 06:32:22 2020 VERIFY OK: depth=1, C=AU, ST=Some-State, O=Internet Widgits Pty Ltd
Jun 15 06:32:22 openvpn[2871]: Mon Jun 15 06:32:22 2020 VERIFY KU OK
Jun 15 06:32:22 openvpn[2871]: Mon Jun 15 06:32:22 2020 Validating certificate extended key usage
Jun 15 06:32:22 openvpn[2871]: Mon Jun 15 06:32:22 2020 ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Serve
r Authentication
Jun 15 06:32:22 openvpn[2871]: Mon Jun 15 06:32:22 2020 VERIFY EKU OK
Jun 15 06:32:22 openvpn[2871]: Mon Jun 15 06:32:22 2020 VERIFY OK: depth=0, CN=vpn.balena-cloud.com
Jun 15 06:32:23 openvpn[2871]: Mon Jun 15 06:32:23 2020 Control Channel: TLSv1.2, cipher TLSv1/SSLv3 ECDHE-RSA-AES256-GCM-SHA384, 2048 bi
t RSA
Jun 15 06:32:23 openvpn[2871]: Mon Jun 15 06:32:23 2020 [vpn.balena-cloud.com] Peer Connection Initiated with [AF_INET]35.169.76.143:443
Jun 15 06:32:24 openvpn[2871]: Mon Jun 15 06:32:24 2020 SENT CONTROL [vpn.balena-cloud.com]: ‘PUSH_REQUEST’ (status=1)
Jun 15 06:32:24 openvpn[2871]: Mon Jun 15 06:32:24 2020 PUSH: Received control message: ‘PUSH_REPLY,sndbuf 0,rcvbuf 0,route 52.4.252.97,p
Jun 15 06:32:24 openvpn[2871]: Mon Jun 15 06:32:24 2020 OPTIONS IMPORT: timers and/or timeouts modified
Jun 15 06:32:24 openvpn[2871]: Mon Jun 15 06:32:24 2020 OPTIONS IMPORT: --sndbuf/–rcvbuf options modified
Jun 15 06:32:24 openvpn[2871]: Mon Jun 15 06:32:24 2020 Socket Buffers: R=[369920->369920] S=[87040->87040]
Jun 15 06:32:24 openvpn[2871]: Mon Jun 15 06:32:24 2020 OPTIONS IMPORT: --socket-flags option modified
Jun 15 06:32:24 openvpn[2871]: Mon Jun 15 06:32:24 2020 Socket flags: TCP_NODELAY=1 succeeded
Jun 15 06:32:24 openvpn[2871]: Mon Jun 15 06:32:24 2020 OPTIONS IMPORT: --ifconfig/up options modified
Jun 15 06:32:24 openvpn[2871]: Mon Jun 15 06:32:24 2020 OPTIONS IMPORT: route options modified
Jun 15 06:32:24 openvpn[2871]: Mon Jun 15 06:32:24 2020 OPTIONS IMPORT: peer-id set
Jun 15 06:32:24 openvpn[2871]: Mon Jun 15 06:32:24 2020 OPTIONS IMPORT: adjusting link_mtu to 1627
Jun 15 06:32:24 openvpn[2871]: Mon Jun 15 06:32:24 2020 OPTIONS IMPORT: data channel crypto options modified
Jun 15 06:32:24 openvpn[2871]: Mon Jun 15 06:32:24 2020 Data Channel: using negotiated cipher ‘AES-256-GCM’
Jun 15 06:32:24 openvpn[2871]: Mon Jun 15 06:32:24 2020 Outgoing Data Channel: Cipher ‘AES-256-GCM’ initialized with 256 bit key
Jun 15 06:32:24 openvpn[2871]: Mon Jun 15 06:32:24 2020 Incoming Data Channel: Cipher ‘AES-256-GCM’ initialized with 256 bit key
Jun 15 06:32:24 openvpn[2871]: Mon Jun 15 06:32:24 2020 ROUTE_GATEWAY 10.0.0.138/255.255.255.0 IFACE=eth0 HWADDR=f8:dc:7a:3e:3a:23
Jun 15 06:32:24 openvpn[2871]: Mon Jun 15 06:32:24 2020 TUN/TAP device resin-vpn opened
Jun 15 06:32:24 openvpn[2871]: Mon Jun 15 06:32:24 2020 TUN/TAP TX queue length set to 100
Jun 15 06:32:24 openvpn[2871]: Mon Jun 15 06:32:24 2020 /sbin/ip link set dev resin-vpn up mtu 1500
Jun 15 06:32:24 openvpn[2871]: Mon Jun 15 06:32:24 2020 /sbin/ip addr add dev resin-vpn local 10.240.13.229 peer 52.4.252.97
Jun 15 06:32:24 openvpn[2871]: Mon Jun 15 06:32:24 2020 /etc/openvpn-misc/upscript.sh resin-vpn 1500 1555 10.240.13.229 52.4.252.97 init
Jun 15 06:32:24 openvpn[2871]: resin-ntp-config: Found config.json in /mnt/boot/config.json .
Jun 15 06:32:24 openvpn[2871]: Mon Jun 15 06:32:24 2020 /sbin/ip route add 52.4.252.97/32 via 52.4.252.97
Jun 15 06:32:24 openvpn[2871]: ip: RTNETLINK answers: File exists
Jun 15 06:32:24 openvpn[2871]: Mon Jun 15 06:32:24 2020 ERROR: Linux route add command failed: external program exited with error status:
2
Jun 15 06:32:24 openvpn[2871]: Mon Jun 15 06:32:24 2020 GID set to openvpn
Jun 15 06:32:24 openvpn[2871]: Mon Jun 15 06:32:24 2020 UID set to openvpn
Jun 15 06:32:24 openvpn[2871]: Mon Jun 15 06:32:24 2020 Initialization Sequence Completed
Jun 15 06:33:24 openvpn[2871]: Mon Jun 15 06:33:24 2020 [vpn.balena-cloud.com] Inactivity timeout (–ping-restart), restarting
Jun 15 06:33:24 openvpn[2871]: Mon Jun 15 06:33:24 2020 /etc/openvpn-misc/downscript.sh resin-vpn 1500 1555 10.240.13.229 52.4.252.97 res
tart
Jun 15 06:33:24 openvpn[2871]: Mon Jun 15 06:33:24 2020 SIGUSR1[soft,ping-restart] received, process restarting
Jun 15 06:33:24 openvpn[2871]: Mon Jun 15 06:33:24 2020 Restart pause, 5 second(s)
Jun 15 06:33:29 openvpn[2871]: Mon Jun 15 06:33:29 2020 NOTE: the current --script-security setting may allow this configuration to call
Jun 15 06:33:29 openvpn[2871]: Mon Jun 15 06:33:29 2020 TCP/UDP: Preserving recently used remote address: [AF_INET]35.169.76.143:443
Hi, from the vpn logs it does looks like the VPN service is not able to start. To debug it better, can you help us with the device type, os version, supervisor version and device diagnostics.
device type = Variscite DART-MX8M Mini PLT
os version = [balenaOS 2.50.1+rev1]
supervisor = 11.4.10
how to run diagnostics not from the dashboard?
Hi, it can only be run through dashboard. Since you moved it to production, you should be able to see it.
yes, but if the device is not connected to the internet, i’m unable to run diagonstics
You can run the device diagnostics directly on the device with the scripts at https://github.com/balena-io/device-diagnostics
Hey there @mellerdaniel ,
Can you please confirm that you are seeing this issue only with devices that have been moved from staging environment to the production environment?
Do you have other devices in the production app that were added directly? Are they having this connectivity issue?
Thanks .
hi, we continue in private support for this, ill update if the manner was fixed
