I followed the instructions listed in the 2 links: Turn your old speakers or Hi-Fi into Bluetooth, Airplay and Spotify receivers with a Raspberry Pi and this step-by-step guide
and: Build your own multi-room audio system with Bluetooth, Airplay, and Spotify using Raspberry Pis
yet I can only hear audio output from one device. I have a raspberry pi 4 and raspberry pi 3B+. Using the pi 4 as the master my log showed this:
12.03.21 17:01:40 (-0500) bluetooth AuthorizeService (/org/bluez/hci0/dev_E4_B2_FB_85_C5_46, 0000110d-0000-1000-8000-00805f9b34fb)
12.03.21 17:01:43 (-0500) audio W: [pulseaudio] module-loopback.c: Configured latency of 200.00 ms is smaller than minimum latency, using minimum instead
12.03.21 17:01:43 (-0500) audio W: [pulseaudio] module-loopback.c: Cannot set requested source latency of 66.67 ms, adjusting to 250.00 ms
12.03.21 17:02:09 (-0500) sound-supervisor Playback started, announcing 192.168.10.246 as multi-room master!
12.03.21 17:05:41 (-0500) Supervisor starting
12.03.21 17:00:37 (-0500) audio Setting audio routing rules…
12.03.21 17:00:37 (-0500) audio Routing ‘balena-sound.input’ to ‘snapcast’.
12.03.21 17:00:37 (-0500) audio Routing ‘balena-sound.output’ to ‘alsa_output.bcm2835-jack.stereo-fallback’.
12.03.21 17:00:37 (-0500) audio W: [pulseaudio] main.c: This program is not intended to be run as root (unless --system is specified).
12.03.21 17:00:37 (-0500) audio W: [pulseaudio] server-lookup.c: Unable to contact D-Bus: org.freedesktop.DBus.Error.NotSupported: Unable to autolaunch a dbus-daemon without a $DISPLAY for X11
12.03.21 17:00:37 (-0500) audio W: [pulseaudio] main.c: Unable to contact D-Bus: org.freedesktop.DBus.Error.NotSupported: Unable to autolaunch a dbus-daemon without a $DISPLAY for X11
12.03.21 17:00:42 (-0500) multiroom-server 2021-03-12 22-00-42.436 [Notice] (StreamServer) StreamServer::NewConnection: 172.17.0.1
12.03.21 17:00:47 (-0500) multiroom-client 2021-03-12 22-00-47.469 [Notice] (Alsa) No chunk received for 5000ms. Closing ALSA.
12.03.21 16:58:16 (-0500) bluetooth Bluetooth agent started!
12.03.21 16:58:16 (-0500) bluetooth Checking for known bluetooth devices…
12.03.21 16:57:42 (-0500) spotify Starting Spotify plugin…
12.03.21 16:57:42 (-0500) spotify Device name: balenaSound Spotify 85db
12.03.21 16:57:42 (-0500) spotify Volume normalization enabled.
12.03.21 16:57:42 (-0500) spotify Spotify audio cache disabled.
12.03.21 16:57:42 (-0500) spotify [2021-03-12T21:57:42Z INFO librespot] librespot (raspotify v0.16.0) 0adb851 (2020-12-15). Built on 2020-12-30. Build ID: KLdkAvgt
12.03.21 17:01:00 (-0500) airplay Waiting for audioblock to start…
12.03.21 17:01:05 (-0500) airplay Waiting for audioblock to start…
12.03.21 17:01:10 (-0500) airplay Waiting for audioblock to start…
12.03.21 17:01:15 (-0500) airplay Waiting for audioblock to start…
12.03.21 17:01:20 (-0500) airplay Waiting for audioblock to start…
12.03.21 17:01:25 (-0500) airplay Waiting for audioblock to start…
12.03.21 17:01:25 (-0500) airplay Shairport-sync started. Device is discoverable as balenaSound AirPlay 85db
12.03.21 16:56:39 (-0500) upnp gmediarender 0.0.7-git started [ gmediarender 0.0.7-git (libupnp-1.8.4; glib-2.58.1; gstreamer-1.14.4) ].
12.03.21 16:56:39 (-0500) upnp Logging switched off. Enable with --logfile= (or --logfile=stdout for console)
12.03.21 16:56:39 (-0500) upnp Ready for rendering.
12.03.21 17:00:17 (-0500) sound-supervisor Error connecting to audio block - Retry failed: connect ECONNREFUSED 192.168.10.246:4317
12.03.21 17:01:22 (-0500) sound-supervisor Connected to PulseAudio at 192.168.10.246:4317
12.03.21 17:01:22 (-0500) sound-supervisor Server protocol version: 33
12.03.21 17:01:22 (-0500) sound-supervisor Client protocol version: 33
12.03.21 17:01:27 (-0500) sound-supervisor Joining the fleet, requesting master info with fleet-sync…
On the Other hand, my pi3 showed this:
12.03.21 16:58:09 (-0500) upnp Ready for rendering.
12.03.21 16:58:03 (-0500) spotify [2021-03-12T21:58:03Z INFO librespot] librespot (raspotify v0.16.0) 0adb851 (2020-12-15). Built on 2020-12-30. Build ID: KLdkAvgt
12.03.21 16:58:04 (-0500) bluetooth Bluetooth agent started!
12.03.21 16:58:04 (-0500) bluetooth Checking for known bluetooth devices…
12.03.21 16:58:30 (-0500) airplay Waiting for audioblock to start…
12.03.21 16:58:30 (-0500) airplay Shairport-sync started. Device is discoverable as balenaSound AirPlay a605
12.03.21 16:58:19 (-0500) multiroom-server 2021-03-12 21-58-19.311 [Notice] (StreamServer) StreamServer::NewConnection: 172.17.0.1
12.03.21 16:58:19 (-0500) multiroom-server 2021-03-12 21-58-19.456 [Notice] (StreamServer) StreamServer::NewConnection: 172.17.0.1
12.03.21 16:58:19 (-0500) multiroom-server 2021-03-12 21-58-19.459 [Error] (StreamSessionTCP) Error reading message header of length 0: End of file
12.03.21 16:58:19 (-0500) multiroom-server 2021-03-12 21-58-19.460 [Error] (StreamSession) StreamSession write error (msg length: 0): Broken pipe
12.03.21 16:58:19 (-0500) multiroom-server 2021-03-12 21-58-19.460 [Error] (StreamSessionTCP) Error in socket shutdown: Transport endpoint is not connected
12.03.21 16:58:31 (-0500) sound-supervisor Joining the fleet, requesting master info with fleet-sync…
I connected to the pi 4 using bluetooth, and began playing music through the Spotify app. I can hear audio coming from the pi 4, but nothing out of the pi 3. I have started from scratch and even tried a new SD card, but am not sure how to get the multi-room functionality working.
