Simplest working Python GUI with VNC
Hello!
I tried this fantastic example Running a GUI application with balenaCloud and it works very well! Thank you Daniel Andrade!
Now, instead of gnome-calculator or xeyes, I would like to try running a Python program that displays the simplest HelloWorld using any GUI framework.
I’ve tried a few things with Tk and PyQt but ended up in a rabbit hole.
The ultimate goal is to run Luxonis depthai-sdk Quickstart — DepthAI SDK Docs 1.13.0 documentation in the container and view the Visualizer output using VNC, example:
from depthai_sdk import OakCamera
with OakCamera() as oak:
    color = oak.create_camera('color', resolution='1080p')
    oak.visualize([color])
    oak.start(blocking=True)
    # this code doesn't execute until the pipeline is stopped
Any help or code snippets would be greatly appreciated!
Hello @craftonix_aa nice to see that you are trying to visualize outputs through VNC.
Could you please tell us more the issues that you had trying to run Tk or PyQt?
