Electron GUI App along with Python application
Hi Forum,
I have followed :
and I am able to start and see in my display the UI application.
But I have also a Python server application that runs in a forever loop and I would like to run it in the background.
I have tried to start the Python script first and the GUI app does not show in the display.
How can I start both the GUI app based on electron and the Python app in the background?
Thank you.
Hey nice!
Just as a heads up we have an example for balena + electronJS that might help you if you hit any blockers.
I assume you’re running this as a multicontainer application type, then you could have the application server run as a separate container, which also has the nice benefit that updating it wouldn’t stop your frontend :slight_smile:
Hi @robertgzr,
Thanks for your feedback.
I have the resin+Electron+React GUI application running ok in one container.
I was trying to add another application to this container (Python Server app) that will run in the background along with the GUI app.
But I can not make it work. Is this possible? I mean having 2 apps : one GUI and another like a server running together in the same container? or is necessary to create a docker compose to have a multi-container apps?
It should definitely be possible to run them alongside in the same container using something like http://supervisord.org
But yes the other option (and my personally preferred way of doing it - for the sake of maintainability) is to use docker-compose. You can follow our docs if for that as well: https://www.balena.io/docs/learn/develop/multicontainer/
Is there a simple kind of “Hello World” docker compose example using BalenaOS?
Check out this:
@robertgzr,
Is possible to communicate data between 2 different container apps running in the same BalenaOS host?
If yes How? What is the best practice?
You can refer to the official docker-compose documentation for most of these things:
Essentially all services you specify in your compose file will share a network and can reach each other by their names:
version: "2"
services:
web:
    build: .
    ports:
      - "8000"
db:
    image: postgres
    ports:
      - "5432"
This enables the web service to talk to postgres via http://db:5432
Much appreciated @robertgzr
Thank you.
Also commenting more in the approach of running the GUI app and server app in the same container.
I have tried in my Dockerfile.template
CMD [“bash”, “/usr/src/app/start.sh”]
inside start.sh I have started both apps using a bash command like “gui_app && server_app” and vice versa but does not work.
How "supervisor: is different that just start both processes using a bash commandline?
I think you want to do
server_app &
gui_app
to get server_app to run in the background
Using supervisord basically just adds a bunch of features that make it more pain free to manage. Like being able to restart one of the processes, starting additional ones, etc.
@robertgzr,
I will try that.
Thanks again.
