Selecting speakers as Left or Right channel?
Hi all,
I may have missed something when setting up my project, but is there a way to select individual clients to play as the left channel, right channel, or mono, and hopefully easily switch between them?
Many thanks,
Elliott
Hi Elliott, looking at your note, I assume you are referring to balenaSound. If that is correct, unfortunately there is no way to control for left, right, or mono that I am aware of. I checked through the Docs, but just in case I missed it, perhaps you could glance through them to verify it as well: Getting started - Home
