I’ve successfully been able to boot a PI 4 via USB. Only issue I am having is that enabling i2c-gpio overlay prevents the Pi from booting. The Pi will fail if I add the following to config.txt: dtoverlay=i2c-gpio,bus=3,i2c_gpio_delay_us=1,i2c_gpio_sda=26,i2c_gpio_scl=16
If I remove this then it will boot successfully again. I know there are additional i2c busses but unfortunately board I am interfacing with was done before the PI 4 so pins don’t align.
As a workaround I have attempted to dynamically add overlays via dtoverlay command from Host OS, however, this also gives me issues regardless of overlay I try…
root@e5814b7:~# dtoverlay -v -d /resin-boot/overlays i2c-gpio bus=3 i2c_gpio_delay_us=1 i2c_gpio_sda=8 i2c_gpio_scl=7
DTOVERLAY[debug]: Found override bus
DTOVERLAY[debug]: override bus: cell target reg @ offset 0 (size 4)
DTOVERLAY[debug]: Found override i2c_gpio_delay_us
DTOVERLAY[debug]: override i2c_gpio_delay_us: cell target i2c-gpio,delay-us @ offset 0 (size 4)
DTOVERLAY[debug]: Found override i2c_gpio_sda
DTOVERLAY[debug]: override i2c_gpio_sda: cell target gpios @ offset 4 (size 4)
DTOVERLAY[debug]: Found override i2c_gpio_scl
DTOVERLAY[debug]: override i2c_gpio_scl: cell target gpios @ offset 16 (size 4)
DTOVERLAY[debug]: delete_node(/__symbols__)
DTOVERLAY[debug]: Wrote 1023 bytes to '/tmp/.dtoverlays/0_i2c-gpio.dtbo'
DTOVERLAY[debug]: Wrote 1080 bytes to '/sys/kernel/config/device-tree/overlays/0_i2c-gpio/dtbo'
* Failed to apply overlay '0_i2c-gpio' (kernel)
I noticed you mentioned adding this to config.txt but if you do this the API will change it back after a reboot. Could you add it via the Host Configuration options in the Dashboard and see if it makes a difference. Thanks.
Hey rich, I usually do specify via fleet configuration. When I do it this way the Pi will go online, apply the config changes, reboot, and never go back online. If I go and remove the i2c-gio the Pi will boot up and process will repeat.
To add to the problem, it looks like that if we flash a fresh Balena OS 2.53.12 for a given app to an SD Card (not USB boot) that has i2c-gpio defined in fleet configuration the Pi will apply settings, reboot, and never go online again. If we revert to OS 2.51 the problem goes away.
So I think the issue is the latest i2c-gpio.dtbo in OS 2.53.12 is bad. I copied i2c-gpio.dtbo from a mounted 2.51.1 image and replaced 2.53.12 version. Once I did this the device works as normal using i2c-gpio overlay. It works whether booted from SD card or USB boot. So looks like some regression/bug was introduced into latest i2c-gpio overlay.
Hi @adamp – thanks very kindly for the additional information, this definitely helps narrow things down. Just to check, it looks like you have filed a bug for this here; have I got this right? In any case, it seems like this bug captures the issue. I’ll add a note reporting your finding to that report. Once it is resolved, you should get notified automatically.
