BalenaOS 2.82.10 neglects dtoverlay
Hi, I will report on the behavior of dtoverlay on BalenaOS 2.82.10 (latest).
I’m using i2c3 by appending dtoverlay=i2c3,pins_4_5 at the bottom of config.txt on BalenaOS 2.75.0. On this version, /dev/i2c-3 properly appears.
When I tried to upgrade it to BalenaOS 2.82.10 on the same RasPi 4B board, /dev/i2c-3 did not appear.
Are there any modification related to dtoverlay behavior between 2.75.0 and 2.82.10?
Hi @cota, and welcome! I have passed this info over to our OS team for investigation, but I’d like to get some more data in the meantime. Can you share the config.txt file you use for both 2.75 and 2.82, so we can compare them? (I understand they might actually be the same).
And further, can you grab a log for us from each, showing the overlay as active (I suppose ls -al /dev would work) on each of the OS’es, 2.75 and 2.82, so we can again compare? Thanks!
I had the same issue when I upgraded to 2.82.10. Mine appears as “i2c5,pins_12_13” on the balena device configuration dashboard, and appears as dtoverlay=i2c5,pins_12_13 in config.txt.
ls -al /dev output for balenaOS 2.80.5+rev1 (includes i2c5)
total 1
drwxr-xr-x 16 root root        4000 Aug  9 22:00 .
drwxr-xr-x  1 root root        1024 Jul 13 19:27 ..
crw-------  1 root root     10,  61 Aug  9 22:00 ashmem
crw-r--r--  1 root root     10, 235 Aug  9 22:00 autofs
crw-------  1 root root     10,  60 Aug  9 22:00 binder
drwxr-xr-x  2 root root         680 Jan  1  1970 block
drwxr-xr-x  3 root root          60 Jan  1  1970 bus
crw-------  1 root root     10,  62 Aug  9 22:00 cachefiles
drwxr-xr-x  2 root root        2940 Aug  9 22:00 char
crw-------  1 root root      5,   1 Aug  9 22:00 console
crw-------  1 root root     10,  59 Aug  9 22:00 cpu_dma_latency
crw-------  1 root root     10, 203 Feb  7  2020 cuse
drwxr-xr-x  8 root root         160 Jan  1  1970 disk
drwxr-xr-x  2 root root          80 Jan  1  1970 dma_heap
lrwxrwxrwx  1 root root          13 Jan  1  1970 fd -> /proc/self/fd
crw-rw-rw-  1 root root      1,   7 Aug  9 22:00 full
crw-rw-rw-  1 root root     10, 229 Aug  9 22:00 fuse
crw-------  1 root root    254,   0 Aug  9 22:00 gpiochip0
crw-------  1 root root    254,   1 Aug  9 22:00 gpiochip1
crw-------  1 root root    246,   0 Aug  9 22:00 gpiomem
crw-------  1 root root     10, 183 Aug  9 22:00 hwrng
crw-------  1 root root     89,   1 Aug  9 22:00 i2c-1
crw-------  1 root root     89,   5 Aug  9 22:00 i2c-5
lrwxrwxrwx  1 root root          12 Feb  7  2020 initctl -> /run/initctl
drwxr-xr-x  2 root root          60 Jan  1  1970 input
crw-r--r--  1 root root      1,  11 Aug  9 22:00 kmsg
crw-rw-rw-  1 root kvm      10, 232 Aug  9 22:00 kvm
lrwxrwxrwx  1 root root          28 Feb  7  2020 log -> /run/systemd/journal/dev-log
crw-rw----  1 root disk     10, 237 Aug  9 22:00 loop-control
brw-rw----  1 root disk      7,   0 Aug  9 22:00 loop0
brw-rw----  1 root disk      7,   1 Aug  9 22:00 loop1
brw-rw----  1 root disk      7,   2 Aug  9 22:00 loop2
brw-rw----  1 root disk      7,   3 Aug  9 22:00 loop3
brw-rw----  1 root disk      7,   4 Aug  9 22:00 loop4
brw-rw----  1 root disk      7,   5 Aug  9 22:00 loop5
brw-rw----  1 root disk      7,   6 Aug  9 22:00 loop6
brw-rw----  1 root disk      7,   7 Aug  9 22:00 loop7
drwxr-xr-x  2 root root          60 Feb  7  2020 mapper
crw-rw----  1 root video   237,   0 Aug  9 22:00 media0
crw-rw----  1 root video   237,   1 Aug  9 22:00 media1
crw-r-----  1 root kmem      1,   1 Aug  9 22:00 mem
brw-rw----  1 root disk    179,   0 Aug  9 22:00 mmcblk0
brw-rw----  1 root disk    179,   1 Aug  9 22:00 mmcblk0p1
brw-rw----  1 root disk    179,   2 Aug  9 22:00 mmcblk0p2
brw-rw----  1 root disk    179,   3 Aug  9 22:00 mmcblk0p3
brw-rw----  1 root disk    179,   4 Aug  9 22:00 mmcblk0p4
brw-rw----  1 root disk    179,   5 Aug  9 22:00 mmcblk0p5
brw-rw----  1 root disk    179,   6 Aug  9 22:00 mmcblk0p6
drwxrwxrwt  2 root root          40 Jan  1  1970 mqueue
drwxr-xr-x  2 root root          60 Jan  1  1970 net
crw-rw-rw-  1 root root      1,   3 Aug  9 22:00 null
crw-r-----  1 root kmem      1,   4 Aug  9 22:00 port
crw-------  1 root root    108,   0 Feb  7  2020 ppp
crw-rw-rw-  1 root tty       5,   2 Aug  9  2021 ptmx
drwxr-xr-x  2 root root           0 Feb  7  2020 pts
brw-rw----  1 root disk      1,   0 Aug  9 22:00 ram0
brw-rw----  1 root disk      1,   1 Aug  9 22:00 ram1
brw-rw----  1 root disk      1,  10 Aug  9 22:00 ram10
brw-rw----  1 root disk      1,  11 Aug  9 22:00 ram11
brw-rw----  1 root disk      1,  12 Aug  9 22:00 ram12
brw-rw----  1 root disk      1,  13 Aug  9 22:00 ram13
brw-rw----  1 root disk      1,  14 Aug  9 22:00 ram14
brw-rw----  1 root disk      1,  15 Aug  9 22:00 ram15
brw-rw----  1 root disk      1,   2 Aug  9 22:00 ram2
brw-rw----  1 root disk      1,   3 Aug  9 22:00 ram3
brw-rw----  1 root disk      1,   4 Aug  9 22:00 ram4
brw-rw----  1 root disk      1,   5 Aug  9 22:00 ram5
brw-rw----  1 root disk      1,   6 Aug  9 22:00 ram6
brw-rw----  1 root disk      1,   7 Aug  9 22:00 ram7
brw-rw----  1 root disk      1,   8 Aug  9 22:00 ram8
brw-rw----  1 root disk      1,   9 Aug  9 22:00 ram9
crw-rw-rw-  1 root root      1,   8 Aug  9 22:00 random
drwxr-xr-x  2 root root          60 Jan  1  1970 raw
crw-rw-r--  1 root root     10, 242 Aug  9 22:00 rfkill
crw-------  1 root root    239,   0 Aug  9 22:00 rpivid-h264mem
crw-------  1 root root    241,   0 Aug  9 22:00 rpivid-hevcmem
crw-------  1 root root    240,   0 Aug  9 22:00 rpivid-intcmem
crw-------  1 root root    238,   0 Aug  9 22:00 rpivid-vp9mem
lrwxrwxrwx  1 root root           5 Aug  9 22:00 serial0 -> ttyS0
lrwxrwxrwx  1 root root           7 Aug  9 22:00 serial1 -> ttyAMA0
drwxrwxrwt  2 root root          40 Feb  7  2020 shm
crw-------  1 root root     10, 231 Aug  9 22:00 snapshot
drwxr-xr-x  2 root root          80 Feb  7  2020 snd
crw-------  1 root root    153,   0 Aug  9 22:00 spidev0.0
crw-------  1 root root    153,   1 Aug  9 22:00 spidev0.1
lrwxrwxrwx  1 root root          15 Jan  1  1970 stderr -> /proc/self/fd/2
lrwxrwxrwx  1 root root          15 Jan  1  1970 stdin -> /proc/self/fd/0
lrwxrwxrwx  1 root root          15 Jan  1  1970 stdout -> /proc/self/fd/1
crw-rw-rw-  1 root tty       5,   0 Aug  9 22:00 tty
crw--w----  1 root tty       4,   0 Aug  9 22:00 tty0
crw--w----  1 root tty       4,   1 Aug  9 22:00 tty1
crw--w----  1 root tty       4,  10 Aug  9 22:00 tty10
crw--w----  1 root tty       4,  11 Aug  9 22:00 tty11
crw--w----  1 root tty       4,  12 Aug  9 22:00 tty12
crw--w----  1 root tty       4,  13 Aug  9 22:00 tty13
crw--w----  1 root tty       4,  14 Aug  9 22:00 tty14
crw--w----  1 root tty       4,  15 Aug  9 22:00 tty15
crw--w----  1 root tty       4,  16 Aug  9 22:00 tty16
crw--w----  1 root tty       4,  17 Aug  9 22:00 tty17
crw--w----  1 root tty       4,  18 Aug  9 22:00 tty18
crw--w----  1 root tty       4,  19 Aug  9 22:00 tty19
crw--w----  1 root tty       4,   2 Aug  9 22:00 tty2
crw--w----  1 root tty       4,  20 Aug  9 22:00 tty20
crw--w----  1 root tty       4,  21 Aug  9 22:00 tty21
crw--w----  1 root tty       4,  22 Aug  9 22:00 tty22
crw--w----  1 root tty       4,  23 Aug  9 22:00 tty23
crw--w----  1 root tty       4,  24 Aug  9 22:00 tty24
crw--w----  1 root tty       4,  25 Aug  9 22:00 tty25
crw--w----  1 root tty       4,  26 Aug  9 22:00 tty26
crw--w----  1 root tty       4,  27 Aug  9 22:00 tty27
crw--w----  1 root tty       4,  28 Aug  9 22:00 tty28
crw--w----  1 root tty       4,  29 Aug  9 22:00 tty29
crw--w----  1 root tty       4,   3 Aug  9 22:00 tty3
crw--w----  1 root tty       4,  30 Aug  9 22:00 tty30
crw--w----  1 root tty       4,  31 Aug  9 22:00 tty31
crw--w----  1 root tty       4,  32 Aug  9 22:00 tty32
crw--w----  1 root tty       4,  33 Aug  9 22:00 tty33
crw--w----  1 root tty       4,  34 Aug  9 22:00 tty34
crw--w----  1 root tty       4,  35 Aug  9 22:00 tty35
crw--w----  1 root tty       4,  36 Aug  9 22:00 tty36
crw--w----  1 root tty       4,  37 Aug  9 22:00 tty37
crw--w----  1 root tty       4,  38 Aug  9 22:00 tty38
crw--w----  1 root tty       4,  39 Aug  9 22:00 tty39
crw--w----  1 root tty       4,   4 Aug  9 22:00 tty4
crw--w----  1 root tty       4,  40 Aug  9 22:00 tty40
crw--w----  1 root tty       4,  41 Aug  9 22:00 tty41
crw--w----  1 root tty       4,  42 Aug  9 22:00 tty42
crw--w----  1 root tty       4,  43 Aug  9 22:00 tty43
crw--w----  1 root tty       4,  44 Aug  9 22:00 tty44
crw--w----  1 root tty       4,  45 Aug  9 22:00 tty45
crw--w----  1 root tty       4,  46 Aug  9 22:00 tty46
crw--w----  1 root tty       4,  47 Aug  9 22:00 tty47
crw--w----  1 root tty       4,  48 Aug  9 22:00 tty48
crw--w----  1 root tty       4,  49 Aug  9 22:00 tty49
crw--w----  1 root tty       4,   5 Aug  9 22:00 tty5
crw--w----  1 root tty       4,  50 Aug  9 22:00 tty50
crw--w----  1 root tty       4,  51 Aug  9 22:00 tty51
crw--w----  1 root tty       4,  52 Aug  9 22:00 tty52
crw--w----  1 root tty       4,  53 Aug  9 22:00 tty53
crw--w----  1 root tty       4,  54 Aug  9 22:00 tty54
crw--w----  1 root tty       4,  55 Aug  9 22:00 tty55
crw--w----  1 root tty       4,  56 Aug  9 22:00 tty56
crw--w----  1 root tty       4,  57 Aug  9 22:00 tty57
crw--w----  1 root tty       4,  58 Aug  9 22:00 tty58
crw--w----  1 root tty       4,  59 Aug  9 22:00 tty59
crw--w----  1 root tty       4,   6 Aug  9 22:00 tty6
crw--w----  1 root tty       4,  60 Aug  9 22:00 tty60
crw--w----  1 root tty       4,  61 Aug  9 22:00 tty61
crw--w----  1 root tty       4,  62 Aug  9 22:00 tty62
crw--w----  1 root tty       4,  63 Aug  9 22:00 tty63
crw--w----  1 root tty       4,   7 Aug  9 22:00 tty7
crw--w----  1 root tty       4,   8 Aug  9 22:00 tty8
crw--w----  1 root tty       4,   9 Aug  9 22:00 tty9
crw-rw----  1 root dialout 204,  64 Aug  9 22:00 ttyAMA0
crw-rw----  1 root dialout   4,  64 Aug  9 22:00 ttyS0
crw-------  1 root root      5,   3 Aug  9 22:00 ttyprintk
crw-------  1 root root     10, 239 Feb  7  2020 uhid
crw-------  1 root root     10, 223 Feb  7  2020 uinput
crw-rw-rw-  1 root root      1,   9 Aug  9 22:00 urandom
drwxr-xr-x  3 root root          60 Aug  9 22:00 v4l
crw-------  1 root root    248,   0 Aug  9 22:00 vc-mem
crw-------  1 root root    243,   0 Aug  9 22:00 vchiq
crw-------  1 root root    247,   0 Aug  9 22:00 vcio
crw-rw----  1 root tty       7,   0 Aug  9 22:00 vcs
crw-rw----  1 root tty       7,   1 Aug  9 22:00 vcs1
crw-rw----  1 root tty       7,   2 Aug  9 22:00 vcs2
crw-rw----  1 root tty       7,   3 Aug  9 22:00 vcs3
crw-rw----  1 root tty       7,   4 Aug  9 22:00 vcs4
crw-rw----  1 root tty       7,   5 Aug  9 22:00 vcs5
crw-rw----  1 root tty       7,   6 Aug  9 22:00 vcs6
crw-rw----  1 root tty       7, 128 Aug  9 22:00 vcsa
crw-rw----  1 root tty       7, 129 Aug  9 22:00 vcsa1
crw-rw----  1 root tty       7, 130 Aug  9 22:00 vcsa2
crw-rw----  1 root tty       7, 131 Aug  9 22:00 vcsa3
crw-rw----  1 root tty       7, 132 Aug  9 22:00 vcsa4
crw-rw----  1 root tty       7, 133 Aug  9 22:00 vcsa5
crw-rw----  1 root tty       7, 134 Aug  9 22:00 vcsa6
crw-rw-rw-  1 root root     10,  58 Aug  9 22:00 vcsm-cma
crw-rw----  1 root tty       7,  64 Aug  9 22:00 vcsu
crw-rw----  1 root tty       7,  65 Aug  9 22:00 vcsu1
crw-rw----  1 root tty       7,  66 Aug  9 22:00 vcsu2
crw-rw----  1 root tty       7,  67 Aug  9 22:00 vcsu3
crw-rw----  1 root tty       7,  68 Aug  9 22:00 vcsu4
crw-rw----  1 root tty       7,  69 Aug  9 22:00 vcsu5
crw-rw----  1 root tty       7,  70 Aug  9 22:00 vcsu6
crw-------  1 root root     10,  63 Aug  9 22:00 vga_arbiter
crw-------  1 root root     10, 137 Feb  7  2020 vhci
crw-------  1 root root     10, 238 Feb  7  2020 vhost-net
crw-rw----  1 root video    81,   7 Aug  9 22:00 video0
crw-rw----  1 root video    81,   1 Aug  9 22:00 video10
crw-rw----  1 root video    81,   4 Aug  9 22:00 video11
crw-rw----  1 root video    81,   6 Aug  9 22:00 video12
crw-rw----  1 root video    81,   0 Aug  9 22:00 video13
crw-rw----  1 root video    81,   2 Aug  9 22:00 video14
crw-rw----  1 root video    81,   3 Aug  9 22:00 video15
crw-rw----  1 root video    81,   5 Aug  9 22:00 video16
crw-------  1 root root     10, 130 Aug  9 22:00 watchdog
crw-------  1 root root    250,   0 Aug  9 22:00 watchdog0
crw-rw-rw-  1 root root      1,   5 Aug  9 22:00 zero
brw-rw----  1 root disk    254,   0 Aug  9 22:00 zram0
ls -al /dev output for balenaOS 2.82.10+rev1 (does not include i2c5)
total 1
drwxr-xr-x 16 root root        4000 Aug  9 23:15 .
drwxr-xr-x  1 root root        1024 Aug  9 22:53 ..
crw-------  1 root root     10,  61 Aug  9 23:15 ashmem
crw-r--r--  1 root root     10, 235 Aug  9 23:15 autofs
crw-------  1 root root     10,  60 Aug  9 23:15 binder
crw-------  1 root root     10,  62 Aug  9 23:15 cachefiles
drwxr-xr-x  2 root root        2960 Aug  9 23:15 char
crw-------  1 root root      5,   1 Aug  9 23:15 console
crw-------  1 root root     10,  59 Aug  9 23:15 cpu_dma_latency
crw-------  1 root root     10, 203 Sep 20  2020 cuse
crw-rw-rw-  1 root root      1,   7 Aug  9 23:15 full
crw-rw-rw-  1 root root     10, 229 Aug  9 23:15 fuse
crw-------  1 root root    254,   0 Aug  9 23:15 gpiochip0
crw-------  1 root root    254,   1 Aug  9 23:15 gpiochip1
crw-------  1 root root    245,   0 Aug  9 23:15 gpiomem
crw-------  1 root root     10, 183 Aug  9 23:15 hwrng
crw-------  1 root root     89,   1 Aug  9 23:15 i2c-1
lrwxrwxrwx  1 root root          12 Sep 20  2020 initctl -> /run/initctl
crw-r--r--  1 root root      1,  11 Aug  9 23:15 kmsg
crw-rw-rw-  1 root kvm      10, 232 Aug  9 23:15 kvm
lrwxrwxrwx  1 root root          28 Sep 20  2020 log -> /run/systemd/journal/dev-log
crw-rw----  1 root disk     10, 237 Aug  9 23:15 loop-control
brw-rw----  1 root disk      7,   0 Aug  9 23:15 loop0
brw-rw----  1 root disk      7,   1 Aug  9 23:15 loop1
brw-rw----  1 root disk      7,   2 Aug  9 23:15 loop2
brw-rw----  1 root disk      7,   3 Aug  9 23:15 loop3
brw-rw----  1 root disk      7,   4 Aug  9 23:15 loop4
brw-rw----  1 root disk      7,   5 Aug  9 23:15 loop5
brw-rw----  1 root disk      7,   6 Aug  9 23:15 loop6
brw-rw----  1 root disk      7,   7 Aug  9 23:15 loop7
drwxr-xr-x  2 root root          60 Sep 20  2020 mapper
crw-rw----  1 root video   235,   0 Aug  9 23:15 media0
crw-rw----  1 root video   235,   1 Aug  9 23:15 media1
crw-r-----  1 root kmem      1,   1 Aug  9 23:15 mem
brw-rw----  1 root disk    179,   0 Aug  9 23:15 mmcblk0
brw-rw----  1 root disk    179,   1 Aug  9 23:15 mmcblk0p1
brw-rw----  1 root disk    179,   2 Aug  9 23:15 mmcblk0p2
brw-rw----  1 root disk    179,   3 Aug  9 23:15 mmcblk0p3
brw-rw----  1 root disk    179,   4 Aug  9 23:15 mmcblk0p4
brw-rw----  1 root disk    179,   5 Aug  9 23:15 mmcblk0p5
brw-rw----  1 root disk    179,   6 Aug  9 23:15 mmcblk0p6
crw-rw-rw-  1 root root      1,   3 Aug  9 23:15 null
crw-r-----  1 root kmem      1,   4 Aug  9 23:15 port
crw-------  1 root root    108,   0 Sep 20  2020 ppp
drwxr-xr-x  2 root root           0 Sep 20  2020 pts
brw-rw----  1 root disk      1,   0 Aug  9 23:15 ram0
brw-rw----  1 root disk      1,   1 Aug  9 23:15 ram1
brw-rw----  1 root disk      1,  10 Aug  9 23:15 ram10
brw-rw----  1 root disk      1,  11 Aug  9 23:15 ram11
brw-rw----  1 root disk      1,  12 Aug  9 23:15 ram12
brw-rw----  1 root disk      1,  13 Aug  9 23:15 ram13
brw-rw----  1 root disk      1,  14 Aug  9 23:15 ram14
brw-rw----  1 root disk      1,  15 Aug  9 23:15 ram15
brw-rw----  1 root disk      1,   2 Aug  9 23:15 ram2
brw-rw----  1 root disk      1,   3 Aug  9 23:15 ram3
brw-rw----  1 root disk      1,   4 Aug  9 23:15 ram4
brw-rw----  1 root disk      1,   5 Aug  9 23:15 ram5
brw-rw----  1 root disk      1,   6 Aug  9 23:15 ram6
brw-rw----  1 root disk      1,   7 Aug  9 23:15 ram7
brw-rw----  1 root disk      1,   8 Aug  9 23:15 ram8
brw-rw----  1 root disk      1,   9 Aug  9 23:15 ram9
crw-rw-rw-  1 root root      1,   8 Aug  9 23:15 random
crw-rw-r--  1 root root     10, 242 Aug  9 23:15 rfkill
crw-------  1 root root    237,   0 Aug  9 23:15 rpivid-h264mem
crw-------  1 root root    239,   0 Aug  9 23:15 rpivid-hevcmem
crw-------  1 root root    238,   0 Aug  9 23:15 rpivid-intcmem
crw-------  1 root root    236,   0 Aug  9 23:15 rpivid-vp9mem
lrwxrwxrwx  1 root root           5 Aug  9 23:15 serial0 -> ttyS0
lrwxrwxrwx  1 root root           7 Aug  9 23:15 serial1 -> ttyAMA0
drwxrwxrwt  2 root root          40 Sep 20  2020 shm
crw-------  1 root root     10, 231 Aug  9 23:15 snapshot
drwxr-xr-x  2 root root          80 Sep 20  2020 snd
crw-------  1 root root    153,   0 Aug  9 23:15 spidev0.0
crw-------  1 root root    153,   1 Aug  9 23:15 spidev0.1
crw-rw-rw-  1 root tty       5,   0 Aug  9 23:15 tty
crw--w----  1 root tty       4,   0 Aug  9 23:15 tty0
crw--w----  1 root tty       4,   1 Aug  9 23:15 tty1
crw--w----  1 root tty       4,  10 Aug  9 23:15 tty10
crw--w----  1 root tty       4,  11 Aug  9 23:15 tty11
crw--w----  1 root tty       4,  12 Aug  9 23:15 tty12
crw--w----  1 root tty       4,  13 Aug  9 23:15 tty13
crw--w----  1 root tty       4,  14 Aug  9 23:15 tty14
crw--w----  1 root tty       4,  15 Aug  9 23:15 tty15
crw--w----  1 root tty       4,  16 Aug  9 23:15 tty16
crw--w----  1 root tty       4,  17 Aug  9 23:15 tty17
crw--w----  1 root tty       4,  18 Aug  9 23:15 tty18
crw--w----  1 root tty       4,  19 Aug  9 23:15 tty19
crw--w----  1 root tty       4,   2 Aug  9 23:15 tty2
crw--w----  1 root tty       4,  20 Aug  9 23:15 tty20
crw--w----  1 root tty       4,  21 Aug  9 23:15 tty21
crw--w----  1 root tty       4,  22 Aug  9 23:15 tty22
crw--w----  1 root tty       4,  23 Aug  9 23:15 tty23
crw--w----  1 root tty       4,  24 Aug  9 23:15 tty24
crw--w----  1 root tty       4,  25 Aug  9 23:15 tty25
crw--w----  1 root tty       4,  26 Aug  9 23:15 tty26
crw--w----  1 root tty       4,  27 Aug  9 23:15 tty27
crw--w----  1 root tty       4,  28 Aug  9 23:15 tty28
crw--w----  1 root tty       4,  29 Aug  9 23:15 tty29
crw--w----  1 root tty       4,   3 Aug  9 23:15 tty3
crw--w----  1 root tty       4,  30 Aug  9 23:15 tty30
crw--w----  1 root tty       4,  31 Aug  9 23:15 tty31
crw--w----  1 root tty       4,  32 Aug  9 23:15 tty32
crw--w----  1 root tty       4,  33 Aug  9 23:15 tty33
crw--w----  1 root tty       4,  34 Aug  9 23:15 tty34
crw--w----  1 root tty       4,  35 Aug  9 23:15 tty35
crw--w----  1 root tty       4,  36 Aug  9 23:15 tty36
crw--w----  1 root tty       4,  37 Aug  9 23:15 tty37
crw--w----  1 root tty       4,  38 Aug  9 23:15 tty38
crw--w----  1 root tty       4,  39 Aug  9 23:15 tty39
crw--w----  1 root tty       4,   4 Aug  9 23:15 tty4
crw--w----  1 root tty       4,  40 Aug  9 23:15 tty40
crw--w----  1 root tty       4,  41 Aug  9 23:15 tty41
crw--w----  1 root tty       4,  42 Aug  9 23:15 tty42
crw--w----  1 root tty       4,  43 Aug  9 23:15 tty43
crw--w----  1 root tty       4,  44 Aug  9 23:15 tty44
crw--w----  1 root tty       4,  45 Aug  9 23:15 tty45
crw--w----  1 root tty       4,  46 Aug  9 23:15 tty46
crw--w----  1 root tty       4,  47 Aug  9 23:15 tty47
crw--w----  1 root tty       4,  48 Aug  9 23:15 tty48
crw--w----  1 root tty       4,  49 Aug  9 23:15 tty49
crw--w----  1 root tty       4,   5 Aug  9 23:15 tty5
crw--w----  1 root tty       4,  50 Aug  9 23:15 tty50
crw--w----  1 root tty       4,  51 Aug  9 23:15 tty51
crw--w----  1 root tty       4,  52 Aug  9 23:15 tty52
crw--w----  1 root tty       4,  53 Aug  9 23:15 tty53
crw--w----  1 root tty       4,  54 Aug  9 23:15 tty54
crw--w----  1 root tty       4,  55 Aug  9 23:15 tty55
crw--w----  1 root tty       4,  56 Aug  9 23:15 tty56
crw--w----  1 root tty       4,  57 Aug  9 23:15 tty57
crw--w----  1 root tty       4,  58 Aug  9 23:15 tty58
crw--w----  1 root tty       4,  59 Aug  9 23:15 tty59
crw--w----  1 root tty       4,   6 Aug  9 23:15 tty6
crw--w----  1 root tty       4,  60 Aug  9 23:15 tty60
crw--w----  1 root tty       4,  61 Aug  9 23:15 tty61
crw--w----  1 root tty       4,  62 Aug  9 23:15 tty62
crw--w----  1 root tty       4,  63 Aug  9 23:15 tty63
crw--w----  1 root tty       4,   7 Aug  9 23:15 tty7
crw--w----  1 root tty       4,   8 Aug  9 23:15 tty8
crw--w----  1 root tty       4,   9 Aug  9 23:15 tty9
crw-rw----  1 root dialout 204,  64 Aug  9 23:15 ttyAMA0
crw-rw----  1 root dialout   4,  64 Aug  9 23:15 ttyS0
crw-------  1 root root      5,   3 Aug  9 23:15 ttyprintk
crw-------  1 root root     10,  58 Aug  9 23:15 ubi_ctrl
crw-------  1 root root     10, 239 Sep 20  2020 uhid
crw-------  1 root root     10, 223 Sep 20  2020 uinput
crw-rw-rw-  1 root root      1,   9 Aug  9 23:15 urandom
drwxr-xr-x  3 root root          60 Aug  9 23:15 v4l
crw-------  1 root root    247,   0 Aug  9 23:15 vc-mem
crw-------  1 root root    241,   0 Aug  9 23:15 vchiq
crw-------  1 root root    246,   0 Aug  9 23:15 vcio
crw-rw----  1 root tty       7,   0 Aug  9 23:15 vcs
crw-rw----  1 root tty       7,   1 Aug  9 23:15 vcs1
crw-rw----  1 root tty       7,   2 Aug  9 23:15 vcs2
crw-rw----  1 root tty       7,   3 Aug  9 23:15 vcs3
crw-rw----  1 root tty       7,   4 Aug  9 23:15 vcs4
crw-rw----  1 root tty       7,   5 Aug  9 23:15 vcs5
crw-rw----  1 root tty       7,   6 Aug  9 23:15 vcs6
crw-rw----  1 root tty       7, 128 Aug  9 23:15 vcsa
crw-rw----  1 root tty       7, 129 Aug  9 23:15 vcsa1
crw-rw----  1 root tty       7, 130 Aug  9 23:15 vcsa2
crw-rw----  1 root tty       7, 131 Aug  9 23:15 vcsa3
crw-rw----  1 root tty       7, 132 Aug  9 23:15 vcsa4
crw-rw----  1 root tty       7, 133 Aug  9 23:15 vcsa5
crw-rw----  1 root tty       7, 134 Aug  9 23:15 vcsa6
crw-rw-rw-  1 root root     10,  57 Aug  9 23:15 vcsm-cma
crw-rw----  1 root tty       7,  64 Aug  9 23:15 vcsu
crw-rw----  1 root tty       7,  65 Aug  9 23:15 vcsu1
crw-rw----  1 root tty       7,  66 Aug  9 23:15 vcsu2
crw-rw----  1 root tty       7,  67 Aug  9 23:15 vcsu3
crw-rw----  1 root tty       7,  68 Aug  9 23:15 vcsu4
crw-rw----  1 root tty       7,  69 Aug  9 23:15 vcsu5
crw-rw----  1 root tty       7,  70 Aug  9 23:15 vcsu6
crw-------  1 root root     10,  63 Aug  9 23:15 vga_arbiter
crw-------  1 root root     10, 137 Sep 20  2020 vhci
crw-------  1 root root     10, 238 Sep 20  2020 vhost-net
crw-rw----  1 root video    81,   7 Aug  9 23:15 video0
crw-rw----  1 root video    81,   2 Aug  9 23:15 video10
crw-rw----  1 root video    81,   5 Aug  9 23:15 video11
crw-rw----  1 root video    81,   6 Aug  9 23:15 video12
crw-rw----  1 root video    81,   0 Aug  9 23:15 video13
crw-rw----  1 root video    81,   1 Aug  9 23:15 video14
crw-rw----  1 root video    81,   3 Aug  9 23:15 video15
crw-rw----  1 root video    81,   4 Aug  9 23:15 video16
crw-------  1 root root     10, 130 Aug  9 23:15 watchdog
crw-------  1 root root    249,   0 Aug  9 23:15 watchdog0
crw-rw-rw-  1 root root      1,   5 Aug  9 23:15 zero
brw-rw----  1 root disk    254,   0 Aug  9 23:15 zram0
Hi @dtischler , thank you for your response.
I attached my config.txt and the output of ls -al /dev for 2.75.0 and 2.82.10.
config.txt (35.8 KB)
dev_with_2.75.0.txt (10.4 KB)
dev_with_2.82.10.txt (10.3 KB)
Thanks @Cota – we’ll check it out!
Hi, we have now identified this as a problem with the v2.82.10 release that affects the RPI4 (see Device tree overlays not working in >= 2.82.10+rev1 for aarch64 device types · Issue #695 · balena-os/balena-raspberrypi · GitHub) . We are already integrating a fix and we should have a new release available shortly. We will update this ticket once the release is available.
I understand what happens! I appreciate your great effort on this problem.
Thanks!! :slight_smile:
@Cota We just released a new version of the OS (version 2.83.10+rev1) that should include a fix for this issue. Go ahead and give it another try if you have a moment, thanks!
Thank you very much!
I’ll try it soon
