Actually, I have followed the migration instructions in the link below and I have succeeded to migrate amd64/ubuntu16 cards without any troubles. But the problem occurs with rapsbian-9, the process (execution logs) seems to be fine, I have received “migration successful, please reboot system”. After the reboot, nothing changes, it booted to raspbian-9 and not from the modified initramfs.
As you may have already noticed, that repository is slated for deprecation. We should be able to help you migrate the device directly, I have reached out to some folks internally who may be able to help.
Stay tuned, we will reach out again with more information soon!
Then you could basically modify your flow, currently checking out the quickfix branch, and use that. Here’s my expanded flow if that helps, hope I haven’t missed anything.
git clone https://github.com/balena-io-playground/balena-migrate && cd balena-migrate/migratecfg && git checkout quickfix This is while we are checking the changes in the quickfix branch, once that is merged, this last part (the git checkout .... will not be needed)
wget https://files.resin.io/resinos/raspberrypi3/2.43.0%2Brev1.dev/image/balena.img.zip In order to download the balenaos rpi3 image. This is unconfigured image, so will need a config.json
unzip balena.img.zip && gzip balena.img
cp balena-migrate-sample.conf balena-migrate.conf
a. then updating the IMAGE_FILE=balena.img.gz environment variable
b. setting BALENA_CONFIG=config.json and create that config.json file there from one config download from the dashboard (navigate to the target application, “Add Device” > “Advanced” > “Download configuration file only”)
c. setting REQUIRE_NMGR_FILE=FALSE
d. set NO_FLASH=FALSE and NO_SETUP=FALSE (can also add DEBUG and LOG_... settings if want to debug further, but not required)
run the migrator sudo ./balena-migrate -c balena-migrate.conf
This succeeded for me on a Raspbian 9 Stretch & Raspberry Pi 3.
If it works for you, we’ll merge the changes, and no extra checkout will be needed, so would be eager to hear your feedback! And the new tool would be generally ore robust in the future.
basename needs to be added, as the stage2 updater uses it, but if not copied in, that step will be broken
sync is also needed to be added, as after file operations it’s good practice to call sync, so that all the changes are written to disk. If not called, the code can operate on half-written data, or move on while changes are not persisted (just kept in memory/buffers). It doesn’t mean data was corrupted, it was just incomplete (moving on too fast).
Actually, during balena-migrate execution, the gzipping process is working fine and a valid backup.tgz was created. The problem occurs after the reboot, the backup.tgz in /mnt/data/ is corrupted for compressed files with a large size.
tar -ztvf backup.tgz
tar: unexpected end of file
tar: short
I have tried that twice with different content to backup in each time. I noticed that the restored tgz file is truncated in both tries, and with a size of 127M.
I understand that the truncating is related to memory limit . Is there a chance to backup compressed content with size ~ 20 GB ? Any suggestion ? Disk repartition before stage 2 ?
hey @omarsastec, are you trying to transfer ~20GB of data, hence that number you mention?
The amount of data that can be transferred depends on the available device memory, as the hard drive is modified completely in the migration process, thus everything that needs to be transferred have to fit into a limited amount of space.
What sort of thing are you trying to migrate over, if we may ask? Just to understand your use case better. Are these database files, videos, some other large files? Could any of those actually be part of your application data on the balena side? We appreciate any context that you could share.
Yeah, I would agree that external storage or some other way to transfer the videos are much better in this case. The backup is mostly conceived to provide a way of getting in settings files, or other smaller stuff that are unique to a device.
The tar/gzip’ing is used, as the device is restoring from a single file, that can hold all folder structure and other file metadata, the compression is sort of secondary aspect, anyways.
Like i have already mentioned, transferring data to an external storage isn’t yet an option.
Isn’t it possible to ensure partial disk repartition ? Means before proceeding to stage 2, we create a partition that holds backup data, then we proceed by installing balena in the left space.
Unfortunately, as mentioned, this is a deprecated project and we don’t support partial repartitioning. As Greg says, balenaOS expects to be installed on an entire media device, as it also dynamically reconfigures the remaining partition space at first boot. Because of this, any changes to the same media node being used to install balenaOS on will be destroyed.
Currently I believe your only option is to store this backup data on an external media node.
