balena push ARM fails
balena push INUC is fine
We encountered an error when reaching this balena.io device:
UUID 6e02
tunneling socket could not be established: 500
One possible reason is because nothing is listening on port 80 on the device.
UUID 6e02
Hi Clive, I tested this on a Raspberry Pi yesterday and it was working, what device type are you using for your Arm device?
happy to enable support access and DM you the guid if that helps
Great!
