Ichus
August 3, 2018, 2:02pm
1
I’m trying to connect a raspberrypi3 with Resin OS 2.13.6+rev1 installed to the wifi network i’m working in. The problem here is, that
nmcli device wifi rescan
nmcli device wifi list
results in this list:
SSID MODE CHAN RATE SIGNAL BARS SECURITY
with no entries.
majorz
August 3, 2018, 2:04pm
4
Are you running nmcli from the host OS or a terminal connected to the application container?
Ichus
August 3, 2018, 2:13pm
5
I’m running nmcli from the terminal using a connection to HostOS
majorz
August 3, 2018, 2:49pm
6
Can you please provide me a dashboard link with support access enabled for the device in a private message? I can enable debug logging in NetworkManager and check for the potential reason.
Ichus
August 3, 2018, 3:11pm
7
Thanks for the help, but the problem was a defect Wifi-Module on the pi.
The issue resolved after exchanging the pi.
majorz
August 3, 2018, 3:38pm
8
Thanks for the follow up! Glad that it is resolved.
