ResinOS (hass.io) on HP t610
Hi forum!
I have a HP t610 which i want to use with hass.io (based on resinOS)
I have tried the intel nuc image, but i cant get it to boot. Do i really have to get a nuc to boot it or am i doing something wrong?
The error is: systemd caught ill dumped core as pid 255
Info about the t610: https://www.cnet.com/products/hp-flexible-thin-client-t610-g-t56n-1-65-ghz-monitor-none-series/specs/2
Thanks :slight_smile:
you are referring to resinOS (https://resinos.io/) and not to resin platform (https://resin.io), is that correct?
Have you managed to install resinOS to your device? You can check here if your device is supported: https://resinos.io/docs/supportedboards/
Best,
ilias
Thank you for your reply!
yes, that is correct and no it freezes at the mentioned error. It says Intel x86_64 so I assumed it would work on a compatible cpu, but I was wrong i guess.
@843 – Did you ever get this working? I’m running into the same error trying to run the Hass.io NUC image in a KVM on Fedora Server.
