I’ve been using resinos Resin OS 2.0.0-rc1.rev2 developer and every time that I do a resin local push -s . it re-pulls the image in the Dockerfile FROM line…
* Building..
- Stopping and Removing any previous 'hb' container
- Building new 'hb' image
Step 1 : FROM resin/raspberrypi3-node:latest
I can’t seem to find a way to make this stop - it sort of makes the local development mode less efficient then OTA deploys from resin.io because unpacking the layers takes a long time on the SD card it seems.
Hi, this is strange. I’ve seen this behaviour before for a bit, but when I was trying it just now, I couldn’t reproduce it. It caches just fine.
Would it be possible to share your project with us, so we can try to run the same code as you did, see why it might fail?
@KingJulien resinOS 2.0 has avahi running on the host OS to advertise the device over the network with a .local address (see more in the announcements), and because of that avahi daemon in the application container won’t work.
What are you using the avahi-daemon for? Announcing the device, or something else? There are a few interesting bits of information in the forums for interacting with that hostOS avahi over dbus, which might help, for example.
