Running resin config generate --version 2.13.0 outputs a JSON file which specifies connectivity: connman. This seems out of date or maybe just unused? Downloading a config.json from the dashboard does not container this block.
Is there documentation on accepted keys in the config.json? I’m hoping to modify the device’s hostname, wifi power save settings, and network parameters.
This looks like an stale config.json entry indeed - it would be great if you could file an issue in https://github.com/resin-io/resin-cli/issues so that we can take it from there.
With regards to the accepted keys, we currently don’t have them documented somewhere - I’ve opened an issue in our docs repository that you can subscribe to and I will ping the relevant people - https://github.com/resin-io/docs/issues/859
