New feature: download configuration only
We have a new feature in the resin.io dashboard available.
Now you can change set to download only the config.json file that configures your device, instead of redownloading the entire device image!
How to do that? Where you’d normally download the OS image, hit advanced, and click the setting there. Like this:
Afterwards you can use the resin-cli to inject this config into a burned SD card easily.
resin config inject myapplication.config.json --type raspberrypi3
See resin config inject --help for more details!
What do you think?
Brilliant addition - incredibly helpful! Thanks a lot!
