Resilio + Network drive share - hiring help
Hi all,
My company is looking for some help to put together a balena project to deploy for our employees a simple sync + network share solution.
We’d use:
  • resilio sync (open to suggestions for an alternative - must have : p2p / selective sync / web gui)
  • network share (will be acessed from windows machines mainly)
  • usb storage (any USB drive connected should mount and made available to use as storage location for resilio).
From the resilio web GUI, we want to be able to connect a resilio share, and store sync data onto the USB storage connected to the Pi (we will use Pi4).
The entire USB drive should be made available as a network share. (optional login/password to access)
I could probably figure out to put the pieces together, but I’ve sadly don’t have the time anymore to fiddle with it - even for a few hours.
If you can help, please reach out! (here in the thread or PM)
Important:
We’re planning to submit the app to hub.balena.io when ready since we believe others might find it useful too.
Code will be shared publicly on github regardless.
Sounds like a neat use-case @xyala. Let’s see what the community chimes in with!
