Remote builder responded with HTTP error: 404 Not Found
balena push EdgeDevice
404 Not Found
Hello @otahir21 first of all welcome to the balena community!
Could you please let us know the balena CLI version?
i am using 16.6.6
Could you please paste the logs here when type
balena push EdgeDevice --debug
@otahir21 could you please use the slug of your fleet instead of the name? You can copy the slug on your balenaCloud dashboard.
i do it but same 404 error is showing me.
do you have access with the user that you do balena login to this fleet @otahir21 ?
at that time i dont have but i logout it and login it again and run this “push” command
same error is showing.
could you please confirm that your user has access to that fleet? could you please share images or logs? we doon’t see any logs about that push in the last hours! thanks :slight_smile:
i copy the same command from create release → Add release
i send you the terminal response
i was trying to push code from last few days but same error is showing.
by running this command “balena push EdgeDevice --debug” i get this in log
The error
Remote builder responded with HTTP error: 404 Not Found means the server couldn’t find the requested information. This could be due to a wrong URL, a deleted/moved resource, or temporary server issues. Double-check the URL, ensure the resource exists, and try again later if it’s a temporary problem. If using an API or service, check their documentation or contact support for assistance.
Can you please briefly tell me how to check a URL?
did you try balena push abdul_mannan_rauf/edgedevice?
yes it was same i dont no why
Hi @otahir21
Did you figure it out?
I’m stuck on the same thing and can’t find any other help.
@andrea the previous user was not using the complete slug! Feel free to copy and paste the slug, check my screenshot below:
If that doesn’t work, could you please share what are you doing?
Sorry for the mistake.
I was using balena-cloud, but I migrated the project to open-balena, and the error occurred because I was using the wrong command.
Sorry again.
