408 Request Timeout when doing balena push
Hi, I am constantly getting errors today when trying balena push. It happened 80% of the time yesterday and 100% of the time today:
Remote builder responded with HTTP error:
408 Request Timeout
Balena Status shows “All Systems Operational”: https://status.balena.io/
Is there something wrong on my side?
Debug output (username and fleet name redacted):
Packaging the project source...[Debug]   Tarring complete in 1370 ms
[debug] Connecting to builder at https://builder.balena-cloud.com/v3/build?slug=our_username%2Four_fleet&dockerfilePath=&emulated=false&nocache=false&headless=false&isdraft=false
408 Request Timeout
ExpectedError: Remote builder responded with HTTP error:
408 Request Timeout
    at Request.<anonymous> (/snapshot/balena-cli/build/utils/remote-build.js:250:21)
    at Object.onceWrapper (node:events:633:26)
    at Request.emit (node:events:518:28)
    at Request.emit (node:domain:488:12)
    at Request.onRequestResponse (/snapshot/balena-cli/node_modules/request/request.js:1059:10)
    at ClientRequest.emit (node:events:530:35)
    at ClientRequest.emit (node:domain:488:12)
    at HTTPParser.parserOnIncomingClient [as onIncoming] (node:_http_client:693:27)
    at HTTPParser.parserOnHeadersComplete (node:_http_common:119:17)
    at TLSSocket.socketOnData (node:_http_client:535:22)
    at TLSSocket.emit (node:events:518:28)
    at TLSSocket.emit (node:domain:488:12)
    at addChunk (node:internal/streams/readable:559:12)
    at readableAddChunkPushByteMode (node:internal/streams/readable:510:3)
    at Readable.push (node:internal/streams/readable:390:5)
    at TLSWrap.onStreamRead (node:internal/stream_base_commons:190:23)
It’s working this morning. I have not changed anything on my side. I suspect there was a service down on the Balena side that was not reflected in the Balena Status page that has since been fixed.
Hello @BrianPTL first of all welcome to the balena community!
Thanks for confirming that suddently it built well today! I will ping the team and check what could happen 2 days ago!
Let us know if we can help you with anything else!
@BrianPTL do you by any chance run with debug logs via the CLI when you were having issues?
We don’t see anything on our side but it could have been a regional networking issue, or something else we would need to track down with more log messages.
Hello I have the same issue
408 Request Timeout
408 Request Timeout
I face this issue only if I push via a Starlink connection. With landline connection is ok.
Any workaround?
Hello @pgiotis could you please confirm how are you pushing?
is your connectivity through Starlink? is your release very big?
I am pushing with command.
balena push fleet-slug
Yes, my connectivity is through Starlink.
It seems that the .dockerignore that I have in the root folder does not work and trying to push the node_modules. I manually delete the node_modules and after that the push action is complete.
You can see the .dockerignore below
build/
node_modules/
.next
thanks for sharing that removing the node_modules worked properly @pgiotis
Let us know how we can help you more!
