Reduce the number of fields by default that show on the devices page on the dashboard
In the dashbooard, when you go to a fleet and then devices almost every field will be enabled for display by default. Then it takes a long time to turn off every field (although that has gotten considerably faster). Then after an update your view will be forgotten and then on every device you use balena on you have to go back through and filter out fields you don’t want. At work many developers have given up and just deal with it. Others have made bookmarks that run javascript to reduce the fields down to what they want.
It would be nice if the default was a much smaller list and then people could enable what they wanted and after updates that view is still remembered so you don’t have to reconfigure it on every device you use.
Chris Crocker-White: I agree with you here Kirt - we should be taking the approach of showing an opinionated minimal set of information (we’ll have to figure out what the most important fields are), and enabling everyone to add what they need.
I also agree that the configuration should then be stored per account rather than in-browser!
