I have some unsupported PC sticks that work quite well with the intel-nuc code. However, after about 2-3 days they consistently lose the connection. I would like to either be able to reboot the Host daily or even better have the host reboot or refresh the network connection when the connection is lost. I am still learning this system so please bear with me. Normally I would just write a bash script and make a cronjob, but resinos does not have cron installed. I can of course install cron into the container, but a reboot of that just reboots the container not the host or the supervisor. I have been looking through the documentation and the forum, but haven’t found anything to point me in the right direction. Any assistance is always appreciated?
Reboot Host and/or Supervisor if it loses connection with dashboard
afitzek
#4
You can use the supervisor API to reboot the device: https://docs.resin.io/reference/supervisor/supervisor-api/#post-v1-reboot
Or if you want to play around with the network connection you can do that via the NetworkManager dbus interface:
- https://docs.resin.io/reference/resinOS/network/2.x/#changing-the-network-at-runtime
- https://developer.gnome.org/NetworkManager/stable/spec.html
Hope this is what you are looking for.
rpelletier
#6
I had searched for APIs to do this but clearly not hard enough. This is absolutely perfect. Thanks for pointing me in the right direction.
