I have been following this guide here:
I have an 8gb unlocked micro sd card inserted in a sd card adapter that’s inserted my 2015 mbp running 10.12.6.
I have formatted the card using disk utility as FAT32 with masterboot record and GUID format options (tried both)
I have download RASPBIAN STRETCH WITH DESKTOP AND RECOMMENDED SOFTWARE from Raspberry Pi OS – Raspberry Pi
I have installed Balena Etcher 1.4.8 for mac
I start the flashing process by selecting the zip file, then selecting the sd card and pressing the flash button.
There is very brief <500ms waiting screen that appears and the I assume the process has finished as there is no error message, nor any feedback to the user that anything has happened.
This appears in the console:
/Applications/balenaEtcher.app/Contents/Resources/app.asar/node_modules/raven-js/dist/raven.js:58 etcher:sdk:scanner stop +45s true
/Applications/balenaEtcher.app/Contents/Resources/app.asar/node_modules/raven-js/dist/raven.js:58 Sun Nov 25 2018 17:59:35 GMT+1100 (AEDT) Flashing 0 devices, 0% at 0 MB/s (total 0 MB/s) eta in undefineds with 0 failed devices
/Applications/balenaEtcher.app/Contents/Resources/app.asar/node_modules/raven-js/dist/raven.js:58 Sun Nov 25 2018 17:59:35 GMT+1100 (AEDT) Flash ({“image”:“/Users/simon/RasberryPiImages/2018-11-13-raspbian-stretch-full.img”,“drives”:[“/dev/disk2”],“driveCount”:1,“uuid”:“2549528d-d152-4204-8096-3827ad55829e”,“status”:“started”,“flashInstanceUuid”:“2549528d-d152-4204-8096-3827ad55829e”,“unmountOnSuccess”:true,“validateWriteOnSuccess”:true,“applicationSessionUuid”:“c660036f-211d-4c8b-b21d-7323b982489a”,“flashingWorkflowUuid”:“2487bef5-1163-4048-bb2b-e841a8538817”})
/Applications/balenaEtcher.app/Contents/Resources/app.asar/node_modules/raven-js/dist/raven.js:58 Elevating command: /Applications/balenaEtcher.app/Contents/Frameworks/balenaEtcher Helper.app/Contents/MacOS/balenaEtcher Helper /Applications/balenaEtcher.app/Contents/Resources/app.asar
/Applications/balenaEtcher.app/Contents/Resources/app.asar/node_modules/raven-js/dist/raven.js:58 Flash results Object {cancelled: true}
/Applications/balenaEtcher.app/Contents/Resources/app.asar/node_modules/raven-js/dist/raven.js:58 Terminating IPC server
/Applications/balenaEtcher.app/Contents/Resources/app.asar/node_modules/raven-js/dist/raven.js:58 Sun Nov 25 2018 17:59:36 GMT+1100 (AEDT) Elevation cancelled ({“status”:“started”,“image”:“/Users/simon/RasberryPiImages/2018-11-13-raspbian-stretch-full.img”,“drives”:[“/dev/disk2”],“driveCount”:1,“uuid”:“2549528d-d152-4204-8096-3827ad55829e”,“flashInstanceUuid”:“2549528d-d152-4204-8096-3827ad55829e”,“unmountOnSuccess”:true,“validateWriteOnSuccess”:true,“applicationSessionUuid”:“c660036f-211d-4c8b-b21d-7323b982489a”,“flashingWorkflowUuid”:“2487bef5-1163-4048-bb2b-e841a8538817”})
/Applications/balenaEtcher.app/Contents/Resources/app.asar/node_modules/raven-js/dist/raven.js:58 etcher:sdk:scanner start +418ms true
I repeat the entire process with the disk image (2018-11-13-raspbian-stretch-full.img) by unzipping the raspbian download.
I am unable to proceed any further.
I check the contents of the card inside Disk Utility, and conclude that nothing has been written to the card.
What am I doing wrong? It’s a bit demoralising to be stuck so early into the process.
This is realtime:
