I’m wondering if that will work with Balena though and eventually how should I configure the networking settings.
Any help will be very useful,
thanks,
Enrico
Hi @enricopenzo , I don’t have an iphone or ipad, but just tested usb tethering with my Google pixel 2, it just works out the box. I just had to plug it into my RPI3, and then enable usb tethering when prompted. This then creates a usb0 interface on the RPI3 that gets an IP. This is super cool, didn’t know it was possible. I would imagine the iphone should be as easy, but I can’t say for sure. balenaOS runs networkManager similar to ubuntu, so you might also have luck if you google usb tether for ubuntu and iphone.
Thanks @shaunmulligan, it sounds promising!
I tried with both iphone and google pixel but not luck so far.
Do you mind to share your networking settings?
I download a balena image with both wifi and ethernet enabled,
many thanks
Sorry, just to clarify, when you say “enable usb tethering when prompted” do you mean through the mobile device interface or raspberry pi display?
I’m running and headless pi at the moment so I can’t see the pi display
Sorry, yeah i had to enable usb tethering from my Google pixel. When i plug my phone into the RPi3, it makes the “charging chime sound” and i have a notification that says “CHarging this device via USB, tap for more options”. if i tap that notifications, i get into the USB preferences page and on that there is an option to select “USB tethering”. Once that is a enabled, i get a second notification that says “Tethering or hotspot active. Tap to set up” and again tapping that takes you to the Hotspot & tethering page and you need to enable “USB tethering” there as well.
I tried to install systemd but it’s not working, I think there might be some conflicts with my NGINX setup.
Do you guys know if there are other alternatives to systemctl I can use in this circumstance?
thanks
This should hopefully allow you to install both in your Dockerfile, use systemd for your init system and therefore use the usbmuxd libraries as intended. If there are any more details you can give us as to why NGINX doesn’t seem to want to coexist, we might be able to offer some more ideas!
Sorry, I probably confused matters. I’d suggest not using that base image because it’s specifically tailored for an AMD64 image, but rolling your own as per the instructions to add systemd referenced earlier. I was just pointing at how we install NGINX alongside systemd in one of our own images. You probably want something like this:
FROM balenalib/amd64-debian:jessie
# Install Systemd
ENV container docker
RUN curl https://nginx.org/keys/nginx_signing.key | apt-key add - \
&& echo 'deb http://nginx.org/packages/debian/ jessie nginx' >> /etc/apt/sources.list \
&& apt-get update && apt-get install -y --no-install-recommends \
systemd \
nginx \
# We never want these to run in a container
# Feel free to edit the list but this is the one we used
RUN systemctl mask \
dev-hugepages.mount \
sys-fs-fuse-connections.mount \
sys-kernel-config.mount \
display-manager.service \
getty@.service \
systemd-logind.service \
systemd-remount-fs.service \
getty.target \
graphical.target
COPY entry.sh /usr/bin/entry.sh
STOPSIGNAL 37
VOLUME ["/sys/fs/cgroup"]
ENTRYPOINT ["/usr/bin/entry.sh"]
# Do things with NGINX config here...
With a relevant entry.sh file. Does this make more sense?
Yes, it makes sense.
I tried to adapt the nginx docker template as follow:
FROM balenalib/rpi-raspbian:stretch
# Install Systemd
RUN apt-get update && apt-get install -y --no-install-recommends \
systemd \
systemd-sysv \
&& echo 'deb http://nginx.org/packages/debian/ stretch nginx' >> /etc/apt/sources.list \
systemd \
nginx \
getty@.service \
getty.target \
graphical.target \
kmod-static-nodes.service
COPY resin.service /etc/systemd/system/resin.service
RUN systemctl enable resin.service
STOPSIGNAL 37
RUN apt-get update && \
apt-get install telnet nano iputils-ping less kmod net-tools ifupdown i2c-tools usbutils wget curl ipheth-utils libimobiledevice-dev libimobiledevice-utils ifuse usbmuxd && \
apt-get clean && \
COPY nginx.service /lib/systemd/system/nginx.service
# Copies the package.json first for better cache on later pushes
COPY package.json package.json
COPY start.sh start.sh
COPY nginx.conf /etc/nginx/nginx.conf
# This will copy all files in our root to the working directory in the container
COPY . /usr/share/nginx/html/
# Enable systemd init system in container
ENV INITSYSTEM on
CMD ["bash", "start.sh"]
Unfortunately the container is not starting.
I might have done some rookie mistake, I’m still pretty new with docker, etc
Any help would be really appreciated
I’m noticing you have both an ENTRYPOINT and a CMD command in your Dockerfile, while one should suffice. Can you also share with us the content of the scripts in either ENTRYPOINT o CMD? One of the most common issues is having an entry point that exits, as that will make the container exit, and what you can do is make the script sleep forever.
Sure, here’s the entry.sh script downloaded from your example:
#!/bin/bash
set -m
if hostname "$HOSTNAME" &> /dev/null; then
PRIVILEGED=true
else
PRIVILEGED=false
fi
# Send SIGTERM to child processes of PID 1.
function signal_handler()
kill "$pid"
function start_udev()
if [ "$UDEV" == "on" ]; then
if [ "$INITSYSTEM" != "on" ]; then
if command -v udevd &>/dev/null; then
unshare --net udevd --daemon &> /dev/null
else
unshare --net /lib/systemd/systemd-udevd --daemon &> /dev/null
fi
udevadm trigger &> /dev/null
fi
else
if [ "$INITSYSTEM" == "on" ]; then
systemctl mask systemd-udevd
fi
fi
function mount_dev()
tmp_dir='/tmp/tmpmount'
mkdir -p "$tmp_dir"
mount -t devtmpfs none "$tmp_dir"
mkdir -p "$tmp_dir/shm"
mount --move /dev/shm "$tmp_dir/shm"
mkdir -p "$tmp_dir/mqueue"
mount --move /dev/mqueue "$tmp_dir/mqueue"
mkdir -p "$tmp_dir/pts"
mount --move /dev/pts "$tmp_dir/pts"
touch "$tmp_dir/console"
mount --move /dev/console "$tmp_dir/console"
umount /dev || true
mount --move "$tmp_dir" /dev
# Since the devpts is mounted with -o newinstance by Docker, we need to make
# /dev/ptmx point to its ptmx.
# ref: https://www.kernel.org/doc/Documentation/filesystems/devpts.txt
ln -sf /dev/pts/ptmx /dev/ptmx
mount -t debugfs nodev /sys/kernel/debug
function init_systemd()
GREEN='\033[0;32m'
echo -e "${GREEN}Systemd init system enabled."
for var in $(compgen -e); do
printf '%q=%q\n' "$var" "${!var}"
done > /etc/docker.env
echo 'source /etc/docker.env' >> ~/.bashrc
printf '#!/bin/bash\n exec ' > /etc/resinApp.sh
printf '%q ' "$@" >> /etc/resinApp.sh
chmod +x /etc/resinApp.sh
mkdir -p /etc/systemd/system/resin.service.d
cat <<-EOF > /etc/systemd/system/resin.service.d/override.conf
[Service]
WorkingDirectory=$(pwd)
EOF
sleep infinity &
exec env DBUS_SYSTEM_BUS_ADDRESS=unix:path=/run/dbus/system_bus_socket /sbin/init quiet systemd.show_status=0
function init_non_systemd()
# trap the stop signal then send SIGTERM to user processes
trap signal_handler SIGRTMIN+3 SIGTERM
# echo error message, when executable file doesn't exist.
if CMD=$(command -v "$1" 2>/dev/null); then
shift
"$CMD" "$@" &
pid=$!
wait "$pid"
exit_code=$?
fg &> /dev/null || exit "$exit_code"
else
echo "Command not found: $1"
exit 1
fi
INITSYSTEM=$(echo "$INITSYSTEM" | awk '{print tolower($0)}')
case "$INITSYSTEM" in
'1' | 'true')
INITSYSTEM='on'
esac
if $PRIVILEGED; then
# Only run this in privileged container
mount_dev
start_udev
fi
if [ "$INITSYSTEM" = "on" ]; then
init_systemd "$@"
else
init_non_systemd "$@"
fi
#!/bin/bash
# disable serial console to enable GPIO serial port
systemctl stop serial-getty@ttyS0.service
systemctl disable serial-getty@ttyS0.service
systemctl enable usbmuxd
systemctl start usbmuxd
echo 'allow-hotplug eth1' >> /etc/network/interfaces
echo 'iface eth1 inet dhcp' >> /etc/network/interfaces
if [ -z "$NGINX_URL" ]; then
echo "No NGINX_URL, using http://192.168.1.111/";
else
echo "NGINX_URL is set to '$NGINX_URL'";
sed -i -e "s@http:\/\/192.168.1.111@$NGINX_URL@g" /etc/nginx/nginx.conf
fi
cat /etc/nginx/nginx.conf
nginx -g "daemon off;"
Yeah, looks like none of those scripts are sleeping forever at the end, so they would exit and therefore make the container exit. Can you try if making the scripts not exit helps?
You need to have one entry point, so you do have to merge the scripts, but that alone doesn’t fix the issue. You need to make your script i.e. sleep forever at the very end to make it not exit.
