The output of dmesg:
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.14.79 (oe-user@oe-host) (gcc version 7.3.0 (GCC)) #1 WedDec 19 20:06:54 UTC 2018
[ 0.000000] CPU: ARMv6-compatible processor [410fb767] revision 7 (ARMv7), cr=00c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
[ 0.000000] OF: fdt: Machine model: Raspberry Pi Zero W Rev 1.1
[ 0.000000] Memory policy: Data cache writeback
[ 0.000000] cma: Reserved 8 MiB at 0x17400000
[ 0.000000] On node 0 totalpages: 98304
[ 0.000000] free_area_init_node: node 0, pgdat c1246c70, node_mem_map d7c8a100
[ 0.000000] Normal zone: 864 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 98304 pages, LIFO batch:31
[ 0.000000] random: get_random_bytes called from start_kernel+0x94/0x438 with crng_init=0
[ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 97440
[ 0.000000] Kernel command line: 8250.nr_uarts=1 bcm2708_fb.fbwidth=1920 bcm2708_fb.fbheight=1080 bcm2708_fb.fbswap=1 smsc95xx.macaddr=B8:27:EB:E3:D5:22 vc_mem.mem_base=0x1ec00000 vc_mem.mem_size=0x20000000 dwc_otg.lpm_enable=0 console=tty1 console=ttyS0,115200 rootfstype=ext4 rootwait root=PARTUUID=f21bbc42-02 rootwait
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Memory: 361552K/393216K available (7299K kernel code, 606K rwdata, 2168Krodata, 8048K init, 676K bss, 23472K reserved, 8192K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
vmalloc : 0xd8800000 - 0xff800000 ( 624 MB)
lowmem : 0xc0000000 - 0xd8000000 ( 384 MB)
modules : 0xbf000000 - 0xc0000000 ( 16 MB)
.text : 0xc0008000 - 0xc0728eb0 (7300 kB)
.init : 0xc09de000 - 0xc11ba000 (8048 kB)
.data : 0xc11ba000 - 0xc1251978 ( 607 kB)
.bss : 0xc1257a5c - 0xc1300cb4 ( 677 kB)
[ 0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] ftrace: allocating 26528 entries in 78 pages
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000037] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483647500ns
[ 0.000088] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
[ 0.000199] bcm2835: system timer (irq = 27)
[ 0.000854] Console: colour dummy device 80x30
[ 0.001498] console [tty1] enabled
[ 0.001569] Calibrating delay loop... 697.95 BogoMIPS (lpj=3489792)
[ 0.050397] pid_max: default: 32768 minimum: 301
[ 0.050985] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.051048] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.052467] CPU: Testing write buffer coherency: ok
[ 0.053977] Setting up static identity map for 0x8200 - 0x8238
[ 0.055399] devtmpfs: initialized
[ 0.067613] VFP support v0.3: implementor 41 architecture 1 part 20 variant b rev 5
[ 0.068132] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.068216] futex hash table entries: 256 (order: -1, 3072 bytes)
[ 0.069895] pinctrl core: initialized pinctrl subsystem
[ 0.071526] NET: Registered protocol family 16
[ 0.075060] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[ 0.082436] hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
[ 0.082517] hw-breakpoint: maximum watchpoint size is 4 bytes.
[ 0.082689] Serial: AMBA PL011 UART driver
[ 0.086262] bcm2835-mbox 2000b880.mailbox: mailbox enabled
[ 0.087193] uart-pl011 20201000.serial: could not find pctldev for node /soc/gpio@7e200000/uart0_pins, deferring probe
[ 0.134489] bcm2835-dma 20007000.dma: DMA legacy API manager at d880d000, dmachans=0x1
[ 0.137155] SCSI subsystem initialized
[ 0.137471] usbcore: registered new interface driver usbfs
[ 0.137604] usbcore: registered new interface driver hub
[ 0.137851] usbcore: registered new device driver usb
[ 0.141065] raspberrypi-firmware soc:firmware: Attached to firmware from 2018-09-21 15:43
[ 0.143476] clocksource: Switched to clocksource timer
[ 0.236902] VFS: Disk quotas dquot_6.6.0
[ 0.237126] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.237483] FS-Cache: Loaded
[ 0.237847] CacheFiles: Loaded
[ 0.258099] NET: Registered protocol family 2
[ 0.259537] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.259690] TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.259830] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.260042] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.260108] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.260560] NET: Registered protocol family 1
[ 0.261489] RPC: Registered named UNIX socket transport module.
[ 0.261552] RPC: Registered udp transport module.
[ 0.261584] RPC: Registered tcp transport module.
[ 0.261612] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.420716] hw perfevents: no irqs for PMU, sampling events not supported
[ 0.420867] hw perfevents: enabled with armv6_1176 PMU driver, 3 counters available
[ 0.425427] workingset: timestamp_bits=14 max_order=17 bucket_order=3
[ 0.439000] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.439580] FS-Cache: Netfs 'nfs' registered for caching
[ 0.441143] NFS: Registering the id_resolver key type
[ 0.441252] Key type id_resolver registered
[ 0.441289] Key type id_legacy registered
[ 0.441346] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.444357] aufs 4.14.56+-20181001
[ 0.448330] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
[ 0.448913] io scheduler noop registered
[ 0.448965] io scheduler deadline registered
[ 0.449608] io scheduler cfq registered (default)
[ 0.449660] io scheduler mq-deadline registered
[ 0.449694] io scheduler kyber registered
[ 0.452528] BCM2708FB: allocated DMA memory 57500000
[ 0.452655] BCM2708FB: allocated DMA channel 0 @ d880d000
[ 0.493514] Console: switching to colour frame buffer device 240x67
[ 0.533440] Serial: 8250/16550 driver, 1 ports, IRQ sharing enabled
[ 0.536977] bcm2835-rng 20104000.rng: hwrng registered
[ 0.537485] vc-mem: phys_addr:0x00000000 mem_base=0x1ec00000 mem_size:0x20000000(512MiB)
[ 0.538946] vc-sm: Videocore shared memory driver
[ 0.539950] gpiomem-bcm2835 20200000.gpiomem: Initialised: Registers at 0x20200000
[ 0.561944] brd: module loaded
[ 0.575950] loop: module loaded
[ 0.576145] Loading iSCSI transport class v2.0-870.
[ 0.577196] tun: Universal TUN/TAP device driver, 1.6
[ 0.577885] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 0.578728] dwc_otg 20980000.usb: base=0xf0980000
[ 0.779434] Core Release: 2.80a
[ 0.779605] Setting default values for core params
[ 0.779813] Finished setting default values for core params
[ 0.980493] Using Buffer DMA mode
[ 0.980666] Periodic Transfer Interrupt Enhancement - disabled
[ 0.980874] Multiprocessor Interrupt Enhancement - disabled
[ 0.981072] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 0.981331] Dedicated Tx FIFOs mode
[ 0.982538] WARN::dwc_otg_hcd_init:1046: FIQ DMA bounce buffers: virt = 0xd7514000 dma = 0x57514000 len=9024
[ 0.982922] FIQ FSM acceleration enabled for :
Non-periodic Split Transactions
Periodic Split Transactions
High-Speed Isochronous Endpoints
Interrupt/Control Split Transaction hack enabled
[ 0.983732] dwc_otg: Microframe scheduler enabled
[ 0.983984] WARN::hcd_init_fiq:459: FIQ on core 0 at 0xc04fb99c
[ 0.984224] WARN::hcd_init_fiq:460: FIQ ASM at 0xc04fbc6c length 36
[ 0.984460] WARN::hcd_init_fiq:486: MPHI regs_base at 0xf0006000
[ 0.984775] dwc_otg 20980000.usb: DWC OTG Controller
[ 0.985034] dwc_otg 20980000.usb: new USB bus registered, assigned bus number 1
[ 0.985374] dwc_otg 20980000.usb: irq 56, io mem 0x00000000
[ 0.985631] Init: Port Power? op_state=1
[ 0.985783] Init: Power Port (0)
[ 0.986385] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.986647] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.986900] usb usb1: Product: DWC OTG Controller
[ 0.987076] usb usb1: Manufacturer: Linux 4.14.79 dwc_otg_hcd
[ 0.997141] usb usb1: SerialNumber: 20980000.usb
[ 1.008350] hub 1-0:1.0: USB hub found
[ 1.018597] hub 1-0:1.0: 1 port detected
[ 1.029558] dwc_otg: FIQ enabled
[ 1.029572] dwc_otg: NAK holdoff enabled
[ 1.029581] dwc_otg: FIQ split-transaction FSM enabled
[ 1.029600] Module dwc_common_port init
[ 1.030236] usbcore: registered new interface driver usb-storage
[ 1.040802] mousedev: PS/2 mouse device common for all mice
[ 1.050938] IR NEC protocol handler initialized
[ 1.060758] IR RC5(x/sz) protocol handler initialized
[ 1.070738] IR RC6 protocol handler initialized
[ 1.080603] IR JVC protocol handler initialized
[ 1.090427] IR Sony protocol handler initialized
[ 1.100270] IR SANYO protocol handler initialized
[ 1.109895] IR Sharp protocol handler initialized
[ 1.119462] IR MCE Keyboard/mouse protocol handler initialized
[ 1.128930] IR XMP protocol handler initialized
[ 1.140249] bcm2835-wdt 20100000.watchdog: Broadcom BCM2835 watchdog timer
[ 1.150811] bcm2835-cpufreq: min=700000 max=1000000
[ 1.161432] sdhci: Secure Digital Host Controller Interface driver
[ 1.171275] sdhci: Copyright(c) Pierre Ossman
[ 1.181991] mmc-bcm2835 20300000.mmc: could not get clk, deferring probe
[ 1.189971] sdhost-bcm2835 20202000.mmc: could not get clk, deferring probe
[ 1.197411] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.205093] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.212286] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.219616] usbcore: registered new interface driver usbhid
[ 1.226687] usbhid: USB HID core driver
[ 1.234827] vchiq: vchiq_init_state: slot_zero = d7580000, is_master = 0
[ 1.244209] [vc_sm_connected_init]: start
[ 1.257699] [vc_sm_connected_init]: end - returning 0
[ 1.266324] nf_conntrack version 0.5.0 (6144 buckets, 24576 max)
[ 1.274484] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 1.281912] Initializing XFRM netlink socket
[ 1.289909] NET: Registered protocol family 10
[ 1.299068] Segment Routing with IPv6
[ 1.306398] NET: Registered protocol family 17
[ 1.313443] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 1.320846] Key type dns_resolver registered
[ 1.329755] registered taskstats version 1
[ 1.344693] uart-pl011 20201000.serial: cts_event_workaround enabled
[ 1.352303] 20201000.serial: ttyAMA0 at MMIO 0x20201000 (irq = 81, base_baud = 0) isa PL011 rev2
[ 1.362193] console [ttyS0] disabled
[ 1.369887] 20215040.serial: ttyS0 at MMIO 0x0 (irq = 160, base_baud = 31250000) is a 16550
[ 2.317718] random: fast init done
[ 2.370534] console [ttyS0] enabled
[ 2.383362] mmc-bcm2835 20300000.mmc: mmc_debug:0 mmc_debug2:0
[ 2.397119] mmc-bcm2835 20300000.mmc: DMA channel allocated
[ 2.465331] sdhost: log_buf @ d7513000 (57513000)
[ 2.515313] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 2.530195] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 2.544897] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 2.560875] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 2.573743] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[ 2.587836] of_cfs_init
[ 2.618152] of_cfs_init: OK
[ 2.654672] Freeing unused kernel memory: 8048K
[ 2.666665] This architecture does not have kernel memory protection.
[ 2.795842] mmc0: host does not support reading read-only switch, assuming write-enable
[ 2.824755] mmc1: new high speed SDIO card at address 0001
[ 2.850661] mmc0: new high speed SDHC card at address aaaa
[ 2.883784] mmcblk0: mmc0:aaaa SC16G 14.8 GiB
[ 2.915578] mmcblk0: p1 p2 p3 p4 < p5 p6 >
[ 7.247317] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 7.433832] EXT4-fs (mmcblk0p5): mounted filesystem with ordered data mode. Opts: (null)
[ 9.030536] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 9.081668] aufs au_opts_verify:1609:init[1]: dirperm1 breaks the protection by the permission bits on the lower branch
[ 9.491337] systemd[1]: System time before build time, advancing clock.
[ 9.561975] systemd[1]: systemd 237 running in system mode. (-PAM -AUDIT -SELINUX +IMA -APPARMOR +SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN -PCRE2 default-hierarchy=hybrid)
[ 9.607679] systemd[1]: Detected architecture arm.
[ 9.664457] systemd[1]: No hostname configured.
[ 9.677591] systemd[1]: Set hostname to <localhost>.
[ 9.709395] systemd[1]: Hardware watchdog 'Broadcom BCM2835 Watchdog timer', version0
[ 9.726200] systemd[1]: Set hardware watchdog to 10s.
[ 10.110939] systemd[1]: File /lib/systemd/system/systemd-journald.service:35 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroupbased firewalling.
[ 10.137079] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 10.955710] systemd[1]: Unnecessary job for /dev/disk/by-partuuid/f21bbc42-02 was removed.
[ 10.973272] systemd[1]: Unnecessary job for /dev/disk/by-label/resin-state was removed.
[ 11.000081] random: systemd: uninitialized urandom read (16 bytes read)
[ 11.044168] random: systemd: uninitialized urandom read (16 bytes read)
[ 11.094178] random: systemd: uninitialized urandom read (16 bytes read)
[ 18.660434] EXT4-fs (mmcblk0p6): mounted filesystem with ordered data mode. Opts: (null)
[ 20.949757] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[ 21.333892] bcm2835_alsa bcm2835_alsa: card created with 8 channels
[ 21.633430] brcmfmac: F1 signature read @0x18000000=0x1541a9a6
[ 21.653996] brcmfmac: brcmf_fw_map_chip_to_name: using brcm/brcmfmac43430-sdio.bin for chip 0x00a9a6(43430) rev 0x000001
[ 21.694017] usbcore: registered new interface driver brcmfmac
[ 22.070647] brcmfmac: brcmf_c_preinit_dcmds: Firmware version = wl0: Oct 23 2017 03:55:53 version 7.45.98.38 (r674442 CY) FWID 01-e58d219f
[ 22.158483] brcmfmac: brcmf_c_preinit_dcmds: CLM version = API: 12.2 Data: 7.11.15 Compiler: 1.24.2 ClmImport: 1.24.1 Creation: 2014-05-26 10:53:55 Inc Data: 9.10.39 Inc Compiler: 1.29.4 Inc ClmImport: 1.36.3 Creation: 2017-10-23 03:47:14
[ 24.386317] EXT4-fs (mmcblk0p3): mounted filesystem with ordered data mode. Opts: (null)
[ 27.838054] uart-pl011 20201000.serial: no DMA platform data
[ 29.017671] random: crng init done
[ 29.030854] random: 7 urandom warning(s) missed due to ratelimiting
[ 32.976554] Bluetooth: Core ver 2.22
[ 33.083878] NET: Registered protocol family 31
[ 33.098320] Bluetooth: HCI device and connection manager initialized
[ 33.413921] i2c /dev entries driver
[ 33.443714] Bluetooth: HCI socket layer initialized
[ 33.443739] Bluetooth: L2CAP socket layer initialized
[ 33.443850] Bluetooth: SCO socket layer initialized
[ 33.521623] Bluetooth: HCI UART driver ver 2.3
[ 33.521636] Bluetooth: HCI UART protocol H4 registered
[ 33.521640] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 33.522525] Bluetooth: HCI UART protocol Broadcom registered
[ 33.573622] brcmfmac: power management disabled
[ 35.309732] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 35.315432] Bluetooth: BNEP filters: protocol multicast
[ 35.363876] Bluetooth: BNEP socket layer initialized
[ 38.094826] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 38.190997] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 38.215956] brcmfmac: power management disabled
[ 38.836953] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 38.871198] brcmfmac: power management disabled
[ 41.062830] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 42.953766] Netfilter messages via NETLINK v0.30.
[ 42.988727] ctnetlink v0.93: registering with nfnetlink.
[ 43.164709] IPv6: ADDRCONF(NETDEV_UP): balena0: link is not ready
[ 44.345325] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 44.391978] brcmfmac: power management disabled
[ 46.084120] Bridge firewalling registered
[ 48.553879] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 51.487463] IPv6: ADDRCONF(NETDEV_UP): br-311ef93d9c05: link is not ready
[ 53.389795] IPv6: ADDRCONF(NETDEV_UP): supervisor0: link is not ready
And journalctl:
-- Logs begin at Wed 2018-12-19 20:04:47 UTC, end at Mon 2019-01-21 22:17:00 UTC. --
Jan 21 22:03:29 3efcda8 balenad[704]: [2019-01-21T22:03:29.774Z] Apply success!
Jan 21 22:03:29 3efcda8 resin-supervisor[1077]: [2019-01-21T22:03:29.774Z] Apply success!
Jan 21 22:03:31 3efcda8 balenad[704]: time="2019-01-21T22:03:31Z" level=info msg="shim reaped" id=a120458bf71f5604689c80d7ca4953a100e75e84920c4359d276038d79e5fc75 module=containerd/ta>
Jan 21 22:03:31 3efcda8 balenad[704]: time="2019-01-21T22:03:31.745972441Z" level=info msg="ignoring event" module=libcontainerd namespace=plugins.moby topic=/tasks/delete type="*even>
Jan 21 22:03:31 3efcda8 balenad[704]: time="2019-01-21T22:03:31.752061315Z" level=info msg="ignoring event" module=libcontainerd namespace=moby topic=/tasks/delete type="*events.TaskD>
Jan 21 22:03:31 3efcda8 balenad[704]: time="2019-01-21T22:03:31.998982179Z" level=info msg="ignoring event" module=libcontainerd namespace=moby topic=/containers/delete type="*events.>
Jan 21 22:03:32 3efcda8 balenad[704]: [2019-01-21T22:03:32.226Z] Event: Service exit {"service":{"appId":1312373,"serviceId":136794,"serviceName":"main","releaseId":753238}}
Jan 21 22:03:32 3efcda8 resin-supervisor[1077]: [2019-01-21T22:03:32.226Z] Event: Service exit {"service":{"appId":1312373,"serviceId":136794,"serviceName":"main","releaseId":753238}}
Jan 21 22:03:44 3efcda8 balenad[704]: time="2019-01-21T22:03:44.889982058Z" level=info msg="ignoring event" module=libcontainerd namespace=moby topic=/containers/create type="*events.>
Jan 21 22:03:45 3efcda8 balenad[704]: time="2019-01-21T22:03:45Z" level=info msg="shim balena-engine-containerd-shim started" address=/containerd-shim/moby/a120458bf71f5604689c80d7ca4>
Jan 21 22:03:47 3efcda8 balenad[704]: time="2019-01-21T22:03:47.191009198Z" level=warning msg="unknown container" container=a120458bf71f5604689c80d7ca4953a100e75e84920c4359d276038d79e>
Jan 21 22:03:48 3efcda8 balenad[704]: time="2019-01-21T22:03:48.426143509Z" level=warning msg="unknown container" container=a120458bf71f5604689c80d7ca4953a100e75e84920c4359d276038d79e>
Jan 21 22:03:50 3efcda8 balenad[704]: time="2019-01-21T22:03:50.114631389Z" level=warning msg="unknown container" container=a120458bf71f5604689c80d7ca4953a100e75e84920c4359d276038d79e>
Jan 21 22:03:52 3efcda8 balenad[704]: time="2019-01-21T22:03:52Z" level=info msg="shim reaped" id=a120458bf71f5604689c80d7ca4953a100e75e84920c4359d276038d79e5fc75 module=containerd/ta>
Jan 21 22:03:52 3efcda8 balenad[704]: time="2019-01-21T22:03:52.275018455Z" level=info msg="ignoring event" module=libcontainerd namespace=plugins.moby topic=/tasks/delete type="*even>
Jan 21 22:03:52 3efcda8 balenad[704]: time="2019-01-21T22:03:52.281145328Z" level=info msg="ignoring event" module=libcontainerd namespace=moby topic=/tasks/delete type="*events.TaskD>
Jan 21 22:03:52 3efcda8 balenad[704]: time="2019-01-21T22:03:52.523215293Z" level=info msg="ignoring event" module=libcontainerd namespace=moby topic=/containers/delete type="*events.>
Jan 21 22:03:52 3efcda8 balenad[704]: [2019-01-21T22:03:52.630Z] Event: Service restart {"service":{"appId":1312373,"serviceId":136794,"serviceName":"main","releaseId":753238}}
Jan 21 22:03:52 3efcda8 resin-supervisor[1077]: [2019-01-21T22:03:52.630Z] Event: Service restart {"service":{"appId":1312373,"serviceId":136794,"serviceName":"main","releaseId":75323>
Jan 21 22:03:52 3efcda8 balenad[704]: [2019-01-21T22:03:52.807Z] Event: Service exit {"service":{"appId":1312373,"serviceId":136794,"serviceName":"main","releaseId":753238}}
Jan 21 22:03:52 3efcda8 resin-supervisor[1077]: [2019-01-21T22:03:52.807Z] Event: Service exit {"service":{"appId":1312373,"serviceId":136794,"serviceName":"main","releaseId":753238}}
Jan 21 22:04:18 3efcda8 balenad[704]: time="2019-01-21T22:04:18.257026053Z" level=info msg="ignoring event" module=libcontainerd namespace=moby topic=/containers/create type="*events.>
Jan 21 22:04:18 3efcda8 balenad[704]: time="2019-01-21T22:04:18Z" level=info msg="shim balena-engine-containerd-shim started" address=/containerd-shim/moby/a120458bf71f5604689c80d7ca4>
Jan 21 22:04:20 3efcda8 balenad[704]: time="2019-01-21T22:04:20.608824137Z" level=warning msg="unknown container" container=a120458bf71f5604689c80d7ca4953a100e75e84920c4359d276038d79e>
Jan 21 22:04:21 3efcda8 balenad[704]: time="2019-01-21T22:04:21.959741039Z" level=warning msg="unknown container" container=a120458bf71f5604689c80d7ca4953a100e75e84920c4359d276038d79e>
Jan 21 22:04:23 3efcda8 balenad[704]: time="2019-01-21T22:04:23.709107654Z" level=warning msg="unknown container" container=a120458bf71f5604689c80d7ca4953a100e75e84920c4359d276038d79e>
Jan 21 22:04:25 3efcda8 balenad[704]: time="2019-01-21T22:04:25Z" level=info msg="shim reaped" id=a120458bf71f5604689c80d7ca4953a100e75e84920c4359d276038d79e5fc75 module=containerd/ta>
I am able to establish a terminal connection but the not with the container. I see some warnings about an unknown container so will try to push a fresh build again just to be sure.
