I am trying to push my code to my staging device, but can’t seem to find out how to do it?
Hi there, can you please provide a bit more information? How are you trying to push your code to the device? What do you mean a “staging” device, you mean an application on “balena-staging.com”? What you normally want to do is set BALENARC_BALENA_URL to balena-staging.com, and then you can then do balena push <appname> as usual, if you are using the CLI. If you are using git, you need to add the remote origin for the staging app to your git repo, and then push to that.
I am trying to push to a device with an image from balena-staging.com using CLI.
- Do i need to login with my staging account?
- How do i set the
BALENARC_BALENA_URLon windows?
Yes, you need to log in with your staging account. The workflow is exactly the same with production, the only difference being the endpoint you are pointing to.
I think on Windows it depends on the terminal tool you are using, and I am not using Windows so I cannot be of much help there I am afraid. A quick search should give you that information though, but let me know if you are still struggling with it and I can ask around people who do use a Windows machine.
Is it just like when i set DEBUG=1?
Yes, it is the same
For future googlers it would be set BALENARC_BALENA_URL=balena-staging.com
You are welcome, and thanks for sharing the info about setting an envvar
