I have been trying to start a minecraft server on my Pi 4, and am brand new to anything related to the Pi. I have been following a tutorial on balena, but when I try to push the server code from the unzipped folder in my terminal, I get an error, saying: " You have to log in to continue
Run the following command to go through the login wizard:
$ balena login
variable: “set DEBUG=1” on a Windows command prompt, “$env:DEBUG = 1” on
powershell, or “export DEBUG=1” on Linux or macOS."
I have tried running this command, with no help. Thanks to anyone who can help.
