Have any body see this error -
SecretRemovalError: pull access denied for balenalib/armhf-alpine, repository does not exist or may require ‘docker login’: denied: requested access to the resource is denied
Yes, that base-image does not exist. If you want an arm based image with hard floating point enabled use this, balenalib/armv7hf-alpine, base image.
Kind regards,
Theodor
