Hello, I poked around the forum for a bit but couldn’t find if there was any support for this particular scenario. I’m evaluating the Etcher portable version on Windows with good results thus far.
My use case is as follows. I’d like to create a wrapper for the Etcher program. The “File to Flash” is known in advance and staged for the end user. In an effort to reduce user error is it possible to tell Etcher (prior to launching) of this known file and have it prepopulated/assigned for the first step so the user does not have to make the selection? I’m just curious if this is possible via command line arg to the .exe or a config file for the program. Thank you for your time.
