Hello, i want ot create a wether station with raspbryy pi and belna clud
but for humidty and temperture sensor i want to use a basic temp sensor (raspbrry pi comtible)
Using the balenaSense project as a starting point might prove useful.
Let me point you to our recent blog post about that, where you can also find the list of officially supported sensors:
Kind regards,
Thodoris
Hello, the air quality supports temperature?
If I’m getting your question right, then yes.
The balenaSense project also supports surfacing temperature, pressure & pressure readings, given that the respective sensor is provided.
Ok, thanks!
