balenaEtcher assumes the logged in user has administrative rights.
I’ve locked down my machine so this is not the case.
The issue is when balenaEtcher asks for a sudo password, the current user doesn’t have admin rights and sudo has no idea what to do with an admin password if it is entered.
I’ve tried the workaround of using sudo from the command line and it works but it does require moving files readable by the logged in user to a shared location (eg. /Users/Shared)
What would be more ideal is to prompt for both the username and password of an Administrator.
I’m not sure how other apps do this as I understand you are merely passing on a sudo prompt to the GUI.
let me know if you have any questions about my configuration. I happen to be on macOS Monterey on MBP 2015.
I have the same problem and I have admin rights, being the only user of my MBP since new. Strangely, my login password does not allow some functions in terminal either. When i check the list of users i am the only one listed. looks like I’ll have to find a different solution to create a bootable linux flash! Thanks anyway! (comments welcome!)
