Orin Nano 8GB without NVME
Hi guys,
I would like to test on a Jetson Orin Nano 8 Gb dev kit but without the NVME disk, I got a SD card.
Is it the same setup to go for ?
Hi @Tomlogan501,
Good question. We don’t test Orin Nano devices using an SD card. In part because while the dev kit has a dev SOM with an SD card slot, the Orin Nano production SOMs do not have an SD card slot. We suggest using NVMe.
I did use a cheap NVME SSD and it worked flawlessly but I will try later with SD Card
