OpenBalena version: v3.2(tried with 3.3 as well)
root@yokoso-tv:~/open-balena# git branch
master
* v3.2.0-branch
v3.3.0-branch
root@yokoso-tv:~/open-balena# docker ps
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
292b0a2c8c7a openbalena_haproxy "/docker-entrypoint.…" 43 minutes ago Up 43 minutes 0.0.0.0:80->80/tcp, 222/tcp, 3128/tcp, 5432/tcp, 0.0.0.0:443->443/tcp, 6379/tcp openbalena_haproxy_1
afc0e268126b balena/open-balena-vpn:v9.17.4 "/usr/bin/entry.sh" 43 minutes ago Up 43 minutes 80/tcp, 443/tcp, 3128/tcp openbalena_vpn_1
1ea57c3fda30 balena/open-balena-api:v0.119.5 "/usr/bin/entry.sh" 43 minutes ago Up 43 minutes 80/tcp openbalena_api_1
a410eac2316e balena/open-balena-registry:v2.14.4 "/usr/bin/entry.sh" 43 minutes ago Up 43 minutes 80/tcp openbalena_registry_1
833a68a57fa6 redis:alpine "docker-entrypoint.s…" 43 minutes ago Up 43 minutes 6379/tcp openbalena_redis_1
d582b3ed373a openbalena_cert-provider "/entry.sh /usr/src/…" 43 minutes ago Up 43 minutes 80/tcp openbalena_cert-provider_1
ec9407fa5e75 balena/open-balena-db:v4.1.0 "/balena-entrypoint.…" 43 minutes ago Up 43 minutes 5432/tcp openbalena_db_1
0fc966e74b6b balena/open-balena-s3:v2.9.9 "/usr/bin/entry.sh" 43 minutes ago Up 43 minutes 80/tcp openbalena_s3_1
Tried to preload an application to the RPi 0 image(It worked well in last month, but suddenly stopped now)
ubuntu@ubuntu-desktop:/$ balena --version
12.44.14
ubuntu@ubuntu-desktop:/$ balena preload raspberrypi_2.67.3_rev1_dev.img --add-certificate ca.crt --app yokosoApp --commit current --splash-image yokosoTVBalena/yokoso/img/splash.jpg --debug
[debug] new argv=[/home/ubuntu/balena-cli/balena,/snapshot/versioned-source/bin/balena,preload,raspberrypi_2.67.3_rev1_dev.img,--add-certificate,ca.crt,--app,yokosoApp,--commit,current,--splash-image,yokosoTVBalena/yokoso/img/splash.jpg] length=12
Building Docker preloader image. [=== ] 12%
Step 1/7 : FROM docker:20.10.6-dind
Building Docker preloader image. [====== ] 25%
Step 2/7 : RUN apk update && apk add --no-cache py3-pip parted btrfs-progs util-linux sfdisk file coreutils sgdisk
---> Using cache
Building Docker preloader image. [========= ] 37%
Step 3/7 : COPY ./requirements.txt /tmp/
---> Using cache
Building Docker preloader image. [============ ] 50%
Step 4/7 : RUN pip3 install -r /tmp/requirements.txt
---> Using cache
Building Docker preloader image. [=============== ] 62%
Step 5/7 : COPY ./src /usr/src/app
---> Using cache
Building Docker preloader image. [================== ] 75%
Step 6/7 : WORKDIR /usr/src/app
---> Using cache
Building Docker preloader image. [===================== ] 87%
Step 7/7 : CMD ["python3", "/usr/src/app/preload.py"]
---> Using cache
---> 0328b01cf811
Successfully built 0328b01cf811
Building Docker preloader image. [========================] 100%
| Checking that the image is a writable file
| Finding a free tcp port and getting balena settings
| Checking if the image is an edison zip archive
/ Creating preloader container
- Starting preloader container
\ Fetching application yokosoapp
/ Reading image informationWaiting for Docker to start...
| Reading image informationDocker started
\ Fetching application 14
| Estimating required additional space
/ Cleaning up temporary files
manifest.manifest.layers is not iterable
TypeError: manifest.manifest.layers is not iterable
at Preloader._getLayersSizes (/snapshot/versioned-source/node_modules/balena-preload/build/preload.js:489:51)
at Preloader._getApplicationSize (/snapshot/versioned-source/node_modules/balena-preload/build/preload.js:507:40)
at runNextTicks (internal/process/task_queues.js:62:5)
at processImmediate (internal/timers.js:429:9)
at process.topLevelDomainCallback (domain.js:137:15)
at async Preloader._getSize (/snapshot/versioned-source/node_modules/balena-preload/build/preload.js:525:16)
at async Preloader._getRequiredAdditionalSpace (/snapshot/versioned-source/node_modules/balena-preload/build/preload.js:531:34)
From previous event:
at processImmediate (internal/timers.js:456:21)
at Preloader.preload (/snapshot/versioned-source/node_modules/balena-preload/build/preload.js:780:14)
at PreloadCmd.prepareAndPreload (/snapshot/versioned-source/build/commands/preload.js:305:25)
at processTicksAndRejections (internal/process/task_queues.js:97:5)
at async PreloadCmd.run (/snapshot/versioned-source/build/commands/preload.js:118:13)
at async PreloadCmd._run (/snapshot/versioned-source/node_modules/@oclif/command/lib/command.js:43:20)
at async Config.runCommand (/snapshot/versioned-source/node_modules/@oclif/config/lib/config.js:175:24)
at async CustomMain.run (/snapshot/versioned-source/node_modules/@oclif/command/lib/main.js:27:9)
at async CustomMain._run (/snapshot/versioned-source/node_modules/@oclif/command/lib/command.js:43:20)
at async Promise.all (index 1)
at async oclifRun (/snapshot/versioned-source/build/app.js:75:5)
at async Object.run (/snapshot/versioned-source/build/app.js:88:9)
https://www.balena.io/docs/reference/balena-cli/#support-faq-and-troubleshooting
Tried with balena cli v12.38.5 and 12.44.0, but all failed.
Seems a bug on the openBalena server?
