I was able to build an openBalena server and deploy a raspberry pi zero w application, but failed to preload my image:
ubuntu@ubuntu-desktop:/media$ balena apps
ID APP NAME SLUG DEVICE TYPE ONLINE DEVICES DEVICE COUNT
1 yokosoApp yokosoapp raspberry-pi 0 0
ubuntu@ubuntu-desktop:/media$ balena preload ../balena-rpi-configured.img --app 1 --commit current --splash-image splash.jpg --debug
Building Docker preloader image. [=== ] 12%
Step 1/7 : FROM docker:17.12.0-ce-dind
Building Docker preloader image. [====== ] 25%
Step 2/7 : RUN apk update && apk add --no-cache python3 parted btrfs-progs util-linux sfdisk file coreutils sgdisk
---> Using cache
Building Docker preloader image. [========= ] 37%
Step 3/7 : COPY ./requirements.txt /tmp/
---> Using cache
Building Docker preloader image. [============ ] 50%
Step 4/7 : RUN pip3 install -r /tmp/requirements.txt
---> Using cache
Building Docker preloader image. [=============== ] 62%
Step 5/7 : COPY ./src /usr/src/app
---> Using cache
Building Docker preloader image. [================== ] 75%
Step 6/7 : WORKDIR /usr/src/app
---> Using cache
Building Docker preloader image. [===================== ] 87%
Step 7/7 : CMD ["python3", "/usr/src/app/preload.py"]
---> Using cache
---> 95c91d1abee6
Successfully built 95c91d1abee6
Building Docker preloader image. [========================] 100%
| Checking that the image is a writable file
| Finding a free tcp port and getting balena settings
| Checking if the image is an edison zip archive
| Creating preloader container
| Starting preloader container
- Fetching application 1
- Cleaning up temporary files
BalenaRequestError: Request error: <!DOCTYPE html>
<html lang="en">
<head>
<meta charset="utf-8">
<title>Error</title>
</head>
<body>
<pre>Cannot GET /v6/application(1)</pre>
</body>
</html>
<html lang="en">
<head>
</head>
<body>
</body>
</html>
at /snapshot/versioned-source/node_modules/balena-request/build/request.js:189:17
From previous event:
at /snapshot/versioned-source/node_modules/balena-request/build/request.js:181:62
at Object.module.exports.exports.send (/snapshot/versioned-source/node_modules/balena-request/build/request.js:180:8)
at /snapshot/versioned-source/node_modules/balena-pine/es2018/index.js:20:22
at runCallback (timers.js:705:18)
at tryOnImmediate (timers.js:676:5)
at processImmediate (timers.js:658:5)
at process.topLevelDomainCallback (domain.js:126:23)
at BalenaPine._request (/snapshot/versioned-source/node_modules/balena-pine/es2018/index.js:12:34)
at BalenaPine.request (/snapshot/versioned-source/node_modules/pinejs-client-core/es2018/index.js:952:29)
at BalenaPine.get (/snapshot/versioned-source/node_modules/pinejs-client-core/es2018/index.js:701:21)
at /snapshot/versioned-source/node_modules/balena-preload/node_modules/balena-sdk/es2018/models/application.js:245:26
at Object.get (/snapshot/versioned-source/node_modules/balena-preload/node_modules/balena-sdk/es2018/models/application.js:239:32)
at Object.get (/snapshot/versioned-source/node_modules/balena-preload/node_modules/balena-sdk/es2018/util/callbacks.js:19:27)
at _fetchApplication._runWithSpinner.Promise.try (/snapshot/versioned-source/node_modules/balena-preload/lib/preload.js:487:49)
at _fetchApplication._runWithSpinner (/snapshot/versioned-source/node_modules/balena-preload/lib/preload.js:485:25)
at Preloader._runWithSpinner (/snapshot/versioned-source/node_modules/balena-preload/lib/preload.js:305:12)
at Preloader._fetchApplication (/snapshot/versioned-source/node_modules/balena-preload/lib/preload.js:481:17)
at prepare._build.then.then.spread.then.then.then.then.then.then.then.then (/snapshot/versioned-source/node_modules/balena-preload/lib/preload.js:628:19)
at Preloader.prepare (/snapshot/versioned-source/node_modules/balena-preload/lib/preload.js:627:6)
at prepareAndPreload (/snapshot/versioned-source/build/actions/preload.js:173:21)
at /snapshot/versioned-source/build/actions/preload.js:347:25
at new Promise (<anonymous>)
at Command.action (/snapshot/versioned-source/build/actions/preload.js:345:19)
Additional information may be available with the `--debug` flag.
For help, visit our support forums: https://forums.balena.io
For bug reports or feature requests, see: https://github.com/balena-io/balena-cli/issues/
ubuntu@ubuntu-desktop:/media$ balena version -a
balena-cli version "12.11.0"
Node.js version "10.21.0"
I even tried balena-cli with 12.2.2, but another error:
ubuntu@ubuntu-desktop:/media$ balena preload ../balena-rpi-configured.img --app yokosoApp --commit current --splash-image splash.jpg --debug
---> Using cache
---> Using cache
---> Using cache
---> Using cache
---> Using cache
---> Using cache
---> c0c061732ecc
Successfully built c0c061732ecc
/ Creating preloader container
- Starting preloader container
\ Fetching application yokosoApp
\ Reading image informationWaiting for Docker to start...
- Reading image informationDocker started
- Resizing partitions and waiting for dockerd to startReplacing splash image
/ Resizing partitions and waiting for dockerd to startExpanding extended partition n°4 of /img/balena.img
Expanding logical partition n°6 of /img/balena.img
| Resizing partitions and waiting for dockerd to startResizing ext4 filesystem of partition n°6 of /img/balena.img using /dev/loop9
/ Resizing partitions and waiting for dockerd to startFile system OK
| Resizing partitions and waiting for dockerd to startWaiting for Docker to start...
\ Resizing partitions and waiting for dockerd to startDocker started
\ Cleaning up temporary files
(HTTP code 500) server error - Get https://registry.yokosotv.com/v2/: x509: certificate signed by unknown authority
Error: (HTTP code 500) server error - Get https://registry.yokosotv.com/v2/: x509: certificate signed by unknown authority
at /snapshot/versioned-source/node_modules/dockerode/node_modules/docker-modem/lib/modem.js:257:17
at IncomingMessage.<anonymous> (/snapshot/versioned-source/node_modules/dockerode/node_modules/docker-modem/lib/modem.js:284:9)
at IncomingMessage.emit (events.js:203:15)
at IncomingMessage.EventEmitter.emit (domain.js:448:20)
at endReadableNT (_stream_readable.js:1143:12)
at process._tickCallback (internal/process/next_tick.js:63:19)
root@ubuntu-desktop:/media# balena apps
root@ubuntu-desktop:/media# balena version -a
balena-cli version "12.2.2"
Node.js version "10.17.0"
How can we fix this issue?
As you could see, I can see the application that was deployed in advance.
And another issue: Cannot SSH into a local development image with 12.2.2!
ubuntu@ubuntu-desktop:~$ sudo balena scan
Reporting scan results
host: yokoso.local
address: 192.168.1.115
dockerInfo:
Containers: 4
ContainersRunning: 2
ContainersPaused: 0
ContainersStopped: 2
Images: 87
Driver: aufs
SystemTime: 2020-10-20T11:38:43.173895986Z
KernelVersion: 4.19.118
OperatingSystem: balenaOS 2.54.2+rev1
Architecture: armv6l
dockerVersion:
Version: 19.03.13-dev
ApiVersion: 1.40
ubuntu@ubuntu-desktop:~$ sudo balena ssh 192.168.1.115 --debug
[debug] new argv=[/home/ubuntu/balena-cli/balena,/snapshot/versioned-source/bin/balena,ssh,192.168.1.115] length=4
Part of the CLI could not be loaded. This typically means your CLI install is in a broken state.
You can normally fix this by uninstalling and reinstalling the CLI.
Error: Cannot find module 'lodash/reduce'
1) If you want to compile the package/file into executable, please pay attention to compilation warnings and specify a literal in 'require' call. 2) If you don't want to compile the package/file into executable and want to 'require' it from filesystem (likely plugin), specify an absolute path in 'require' call using process.cwd() or process.execPath.
at Function.Module._resolveFilename (internal/modules/cjs/loader.js:634:15)
at Function.Module._resolveFilename (pkg/prelude/bootstrap.js:1351:46)
at Function.resolveFilenameOptimized [as _resolveFilename] (/snapshot/versioned-source/node_modules/fast-boot2/index.js:57:33)
at Function.Module._load (internal/modules/cjs/loader.js:560:25)
at Module.require (internal/modules/cjs/loader.js:690:17)
at Module.require (pkg/prelude/bootstrap.js:1230:31)
at require (internal/modules/cjs/helpers.js:25:18)
at Promise.resolve.then (/snapshot/versioned-source/build/utils/device/ssh.js:7:55)
ubuntu@ubuntu-desktop:~$ balena version -a
