CLI balena preload hangs at "Reading image information"
I’ve searched across various similar topics but could not find a solution.
I’m trying to preload an app to an image for flashing, but the process is stuck at “Reading image information”.
Command:
DEBUG=1 balena preload ~/Downloads/balena-cloud-manufacturing-raspberrypi0-2w-64-2.87.16+rev1-v12.11.0.img --fleet manufacturing --commit latest
Output:
[debug] original argv0="/usr/local/lib/balena-cli/bin/node" argv=[/usr/local/lib/balena-cli/bin/node,/usr/local/lib/balena-cli/bin/run,preload,/Users/fritz/Downloads/balena-cloud-manufacturing-raspberrypi0-2w-64-2.87.16+rev1-v12.11.0.img,--fleet,manufacturing,--commit,latest] length=8
[debug] new argv=[/usr/local/lib/balena-cli/bin/node,/usr/local/lib/balena-cli/bin/run,preload,/Users/fritz/Downloads/balena-cloud-manufacturing-raspberrypi0-2w-64-2.87.16+rev1-v12.11.0.img,--fleet,manufacturing,--commit,latest] length=8
[debug] Deprecation check: 0.05941 days since last npm registry query for next major version release date.
[debug] Will not query the registry again until at least 7 days have passed.
[debug] Event tracking error: Timeout awaiting 'response' for 0ms
Building Docker preloader image. [===                     ] 12%
Step 1/7 : FROM alpine:3.12
Building Docker preloader image. [======                  ] 25%
Step 2/7 : WORKDIR /usr/src/app
 ---> Using cache
Building Docker preloader image. [=========               ] 37%
Step 3/7 : RUN apk add --no-cache curl py3-pip parted btrfs-progs util-linux sfdisk file coreutils sgdisk e2fsprogs-extra docker
 ---> Using cache
Building Docker preloader image. [============            ] 50%
Step 4/7 : COPY requirements.txt ./
 ---> Using cache
Building Docker preloader image. [===============         ] 62%
Step 5/7 : RUN pip3 install --no-cache-dir -r requirements.txt
 ---> Using cache
Building Docker preloader image. [==================      ] 75%
Step 6/7 : COPY src/ ./
 ---> Using cache
Building Docker preloader image. [=====================   ] 87%
Step 7/7 : CMD ["python3", "/usr/src/app/preload.py"]
 ---> Using cache
 ---> 0cafc2659267
Successfully built 0cafc2659267
Building Docker preloader image. [========================] 100%
| Checking that the image is a writable file
| Finding a free tcp port
| Checking if the image is an edison zip archive
- Creating preloader container
/ Starting preloader container
- Fetching application matthias1/manufacturing
- Reading image information
Any ideas?
I just tried to do
balena logout
and then balena login.
Now I’m getting the following error:
[debug] Deprecation check: 0.06406 days since last npm registry query for next major version release date.
 ---> Using cache
 ---> Using cache
 ---> Using cache
 ---> Using cache
 ---> Using cache
 ---> Using cache
 ---> 0cafc2659267
| Cleaning up temporary files
(HTTP code 409) unexpected - Conflict. The container name "/balena-image-preloader" is already in use by container "2638bf8a8cf93f05a51607415cb19455aff0c02749e4eae45b83b81047f015ef". You have to remove (or rename) that container to be able to reuse that name.
Error: (HTTP code 409) unexpected - Conflict. The container name "/balena-image-preloader" is already in use by container "2638bf8a8cf93f05a51607415cb19455aff0c02749e4eae45b83b81047f015ef". You have to remove (or rename) that container to be able to reuse that name.
    at /usr/local/lib/balena-cli/node_modules/docker-modem/lib/modem.js:315:17
    at getCause (/usr/local/lib/balena-cli/node_modules/docker-modem/lib/modem.js:345:7)
    at Modem.buildPayload (/usr/local/lib/balena-cli/node_modules/docker-modem/lib/modem.js:314:5)
    at IncomingMessage.<anonymous> (/usr/local/lib/balena-cli/node_modules/docker-modem/lib/modem.js:286:14)
    at IncomingMessage.emit (events.js:326:22)
    at IncomingMessage.EventEmitter.emit (domain.js:483:12)
    at endReadableNT (_stream_readable.js:1241:12)
    at processTicksAndRejections (internal/process/task_queues.js:84:21)
From previous event:
    at processImmediate (internal/timers.js:461:21)
    at Preloader.prepare (/usr/local/lib/balena-cli/node_modules/balena-preload/build/preload.js:660:48)
    at PreloadCmd.prepareAndPreload (/usr/local/lib/balena-cli/build/commands/preload.js:292:25)
    at /usr/local/lib/balena-cli/build/commands/preload.js:129:30
    at new Promise (<anonymous>)
    at PreloadCmd.run (/usr/local/lib/balena-cli/build/commands/preload.js:127:19)
    at processTicksAndRejections (internal/process/task_queues.js:97:5)
    at async PreloadCmd._run (/usr/local/lib/balena-cli/node_modules/@oclif/command/lib/command.js:43:20)
    at async Config.runCommand (/usr/local/lib/balena-cli/node_modules/@oclif/config/lib/config.js:175:24)
    at async CustomMain.run (/usr/local/lib/balena-cli/node_modules/@oclif/command/lib/main.js:27:9)
    at async CustomMain._run (/usr/local/lib/balena-cli/node_modules/@oclif/command/lib/command.js:43:20)
    at async /usr/local/lib/balena-cli/build/app.js:76:13
    at async Promise.all (index 2)
    at async oclifRun (/usr/local/lib/balena-cli/build/app.js:94:5)
    at async Object.run (/usr/local/lib/balena-cli/build/app.js:107:9)
    at async run (/usr/local/lib/balena-cli/bin/run:20:2)
https://www.balena.io/docs/reference/balena-cli/#support-faq-and-troubleshooting
How can I remove (or rename) this container?
So, I could delete the container, now I’m stuck (again) at the previous issue, hanging at “Reading image information”.
I’ll continue here as it might be useful for the community.
As the CLI preloader is using your local docker demon to run the preloading process, it starts a balena-image-preloder container. When it crashed on your first time, that container hasn’t been properly disposed of, so your second attempt fails.
To remove it you can use the docker cli : docker stop balena-image-preloder && docker rm balena-image-preloder.
For your other issue, can you try using the fleet id instead of name ?
I double check and using fleet name should work fine.
Which makes your logout/login a good idea, if it wasn’t stuck by the previous attempt.
Which version of docker and cli are you using ?
Hi @aethernet
thanks for your reply. I’m using Docker version 20.10.17, build 100c701
and Balena CLI 14.5.10
(I upgraded yesterday because it did not work before with 14.4, which I had installed previously).
I’ve been using this command exactly that way for years now, so there must be some new issue somewhere, which I don’t see.
Any ideas?
I’ve just reproduced on my end and will investigate.
In the meantime you can downgrade the CLI (I’ve preloaded with v13.6.0 earlier today successfully).
FYI I just opened a GitHub issue
Sorry, the issue is not with the CLI but with a regression in docker 20.10.17, you can downgrade docker as a workaround. (CLI preloading code didn’t change between 13.6 and 14.5 anyway).
thanks, I can confirm downgrading to Docker Desktop 4.9.1 with Docker Engine 20.10.16 resolved the issue.
Cheers
Awesome !
We’re working on a fix, should be quick.
Just chiming in, waiting for a fix here.
Regards
This should be fixed by v14.5.15
Hi I am facing this problem on
❯ docker --version
Docker version 23.0.1, build a5ee5b1dfc
❯ balena --version
15.1.1
Command run
balena preload <IMAGENAME> --fleet <MYFLEET> --commit <COMMIT ID> -p --splash-image <MYSPLASH>
Output
\ Fetching application <MYFLEET>
\ Reading image information
I think this problem is reappeared on docker version 23.
Anyone else faced this issue on latest docker ?
@aethernet can please check this issue found by @rohitsharmar2p
Hi Marc (@mpous) do you know if there is any upcoming fix for balena-cli for docker version 23 which is showing this issue?
@rohitsharmar2p could you please confirm what OS and machine you were using?
I will try to replicate myself!
Thanks for the ping
Hi @mpous its raspberry pi cm4 and I am running os version 2.112.12
I tried also on intel nuc with os version 2.108.19-prod with same issue
@rohitsharmar2p no, i meant what device are you using to run balena preload?
@mpous
I am using Arch linux
my kernel version is 6.2.10-arch1-1
