Hi all,
I’m having trouble getting devices to register with my open balena instance. I’ve searched through the logs and I can see the supervisor is failing with an empty error message:
event] Event: Device bootstrap {}
[info] New device detected. Provisioning...
[event] Event: Device bootstrap failed, retrying {"delay":30000,"error":{"message":"","stack":"Error\n at /usr/src/app/dist/app.js:22:766911\n at process.processTicksAndRejections (node:internal/process/task_queues:95:5)"}}
This is my config.json I used to configure the image before flashing, although it’s not relevant i’m using a Jetson. I have modified /etc/hosts/ for my openBalena hosts to be found (since i’m not on the open internet) and confirmed that it works with curl. Note that I also generated the API key which I set for apiKey using balena api-key generate myKey. I’ve changed some values for security reasons but I have tested them so far and they work. Please let me know if there’s something I’m doing wrong in the config below:
"network": "wifi",
"wifiSsid": "XXXXXXX",
"wifiKey": "XXXXX",
"appUpdatePollInterval": 10,
"apiEndpoint": "https://api.openbalena.local",
"dnsServers": "192.168.1.216 8.8.8.8",
"balenaRootCA": "XXX...==",
"developmentMode": "true",
"apiKey": "06A9o6XXXXXXX.....9dT",
"sshKeys": [
"sh-rsa XXX...."
"hostname": "device1",
"deviceType": "jetson-xavier-nx-devkit-emmc",
"deviceId": 1,
"applicationName": "XXXX",
"applicationId": 1
Here are my versions:
Here’s my /etc/os-release/ on the device:
ID="balena-os"
NAME="balenaOS"
VERSION="4.0.9+rev2"
VERSION_ID="4.0.9+rev2"
PRETTY_NAME="balenaOS 4.0.9+rev2"
DISTRO_CODENAME="kirkstone"
MACHINE="jetson-xavier-nx-devkit-emmc"
META_BALENA_VERSION="4.0.30"
BALENA_BOARD_REV="e91b715"
META_BALENA_REV="ff47baf2"
SLUG="jetson-xavier-nx-devkit-em
Compose versions (as I’m using docker to run my OpenBalena instance):
export OPENBALENA_API_VERSION_TAG=v0.209.2
export OPENBALENA_DB_VERSION_TAG=v5.1.2
export OPENBALENA_MDNS_PUBLISHER_VERSION_TAG=v1.9.2
export OPENBALENA_REGISTRY_VERSION_TAG=v2.25.3
export OPENBALENA_S3_VERSION_TAG=v2.13.10
export OPENBALENA_VPN_VERSION_TAG=v11.4.6
