I know there has been a lot of effort from the resin.io team to open source the components that are needed to run a private (non-supported) fleet of devices on our own. And it feels like the time is near! Very exciting.
I am wondering what components are needed in order to run a minimal working system. It seems like the following are required:
- resin-api (not yet released as open source?)
- resin-supervisor (running on device and configured to use resin-api service above) – can this use a standard resin image with a custom config file to point to a resin-api service?
- resin-cli (configured to use resin-api service above)
- maybe a image registry?
I might be way off and am likely over simplifying. Anyone have any experience here they can share?
I’m basically trying to make a very crude and minimal version of this work for a few raspberrypi3 devices for a “what-if” demo behind a firewall. For all intents and purposes we should consider the network this system runs on to be air-gapped. No fancy UI, build servers, delta images, etc required.
Can anyone offer help?
