I’ve just installed Etcher Version 1.19.25 (1.19.25) on my Mac mini studio, which is ARM based, running macOS Sequoia 15.3. As this is my main computer I have 5 external drives permanently attached in addition to the internal SSD.
I can find my source file ok. However when I try to select a small SD Card as the target, it only shows me the 5 largest drives in descending order. It looks like there are a couple of buttons (a green and a pink one) just showing at the bottom of the window.
Disk Doctor show the SD Card as being present and formatted with MBR and
Unfortunately I cannot resize the window to show more drives, or even change the sort order to show the smallest at the top.
Is this something I’m doing wrong, a limitation of Etcher, a BUG, or what? I’m pretty sure I didn’t have this problem using Etcher on my previous Mac Pro Late 2013 with the same external drives connected. But that was a couple of years ago!
