hey @BladeRunner,
Welcome to the forums and thanks for using foldforcovid.
From the message above, I think you are hitting CRLF line endings issues.
Can you please confirm the following:
You are using balena CLI on a Windows computer
Are you seeing any warnings like the one below when doing a
balena push?[Warn] CRLF (Windows) line endings detected in file: <path> -
If the above are true, can you try the solution mentioned here:
piHole webinterface not reachable
Thanks
