Here are the steps I did to get this situation :
- I’ve pushed some new Dockerfile with an java app not able to startup. So the logs were looping on “Unable to access jarfile” every 10 sec for ever.
- I’ve “shutdown” via the web UI button my only test device, because I had no time to fix the problem
- I fix the problem and push the new fixed Dockerfile.
- I start the device manually (unplug, re-plug alim).
And after this I had 15 min of this strange message looping (it finally stopped and the new app got deployed) :
18.05.17 19:33:07 (+0200)
18.05.17 19:33:07 (+0200) Frames:
18.05.17 19:33:07 (+0200) ---
18.05.17 19:33:07 (+0200) 0: setupRootfs
18.05.17 19:33:07 (+0200) Package: github.com/opencontainers/runc/libcontainer
18.05.17 19:33:07 (+0200) File: rootfs_linux.go@40
18.05.17 19:33:07 (+0200) 1: Init
18.05.17 19:33:07 (+0200) Package: github.com/opencontainers/runc/libcontainer.(*linuxStandardInit)
18.05.17 19:33:07 (+0200) File: standard_init_linux.go@57
18.05.17 19:33:07 (+0200) 2: StartInitialization
18.05.17 19:33:07 (+0200) Package: github.com/opencontainers/runc/libcontainer.(*LinuxFactory)
18.05.17 19:33:07 (+0200) File: factory_linux.go@240
18.05.17 19:33:07 (+0200) 3: initializer
18.05.17 19:33:07 (+0200) Package: github.com/docker/docker/daemon/execdriver/native
18.05.17 19:33:07 (+0200) File: init.go@35
18.05.17 19:33:07 (+0200) 4: Init
18.05.17 19:33:07 (+0200) Package: github.com/docker/docker/pkg/reexec
18.05.17 19:33:07 (+0200) File: reexec.go@26
18.05.17 19:33:07 (+0200) 5: main
18.05.17 19:33:07 (+0200) Package: main
18.05.17 19:33:07 (+0200) File: docker.go@18
18.05.17 19:33:07 (+0200) 6: main
18.05.17 19:33:07 (+0200) Package: runtime
18.05.17 19:33:07 (+0200) File: proc.go@183
18.05.17 19:33:07 (+0200) 7: goexit
18.05.17 19:33:07 (+0200) File: asm_arm.s@998
18.05.17 19:33:38 (+0200) Timestamp: 2017-05-18 17:33:38.237879002 +0000 UTC
18.05.17 19:33:38 (+0200) Code: System error
18.05.17 19:33:38 (+0200) Message: stat /tmp/resin-supervisor/377605: no such file or directory
So that’s it, I prefer to report it if there is something to fix, even if it finally recovered by itself in my case.
And I humbly suggest the “shutdown” button should be red because it’s an irreversible action if you are not in the same location as the device, not like other actions.
