I have a script that runs inside a container in Balena.
The scripts needs to install Cuda and compile a C++ library.
Sometimes the script works. But often, I get the following error:
/tmp/ccXy0Svl.s: Fatal error: can't close yolo.o: No space left on device
However, there is space on the device, because running df returns:
Filesystem 1K-blocks Used Available Use% Mounted on
overlay 236369912 45325940 178926704 21% /
tmpfs 65536 0 65536 0% /dev
tmpfs 16391176 0 16391176 0% /sys/fs/cgroup
/dev/nvme0n1p6 236369912 45325940 178926704 21% /nvidia
tmpfs 16391176 8 16391168 1% /tmp/resin
shm 65536 0 65536 0% /dev/shm
encrypted_storage: 236369912 57443208 178926704 25% /src/src
Is it possible that there is a limit imposed by Balena on the space that the container can use?
