Hi Guys,
We are using BalenaOS Jetson v4.0.9+rev1 with Jetson Xavier NX EMMC 16GB. Our image is a custom one that was built with balena-jetson. On two of our other Jetson’s we’ve successfully flashed the image and it worked. We recently flashed the image onto a similar model jetson and we haven’t been able to get our images deployed. There’s something weird also about how it gets formatted it’s not the same as the other Jetsons:
Filesystem Size Used Avail Use% Mounted on
devtmpfs 7.4G 0 7.4G 0% /dev
tmpfs 7.8G 9.1M 7.8G 1% /run
/dev/disk/by-state/resin-rootA 677M 407M 220M 65% /mnt/sysroot/active
/dev/disk/by-state/resin-state 18M 407K 16M 3% /mnt/state
overlay 677M 407M 220M 65% /
/dev/mmcblk0p13 13G 5.4G 6.4G 46% /mnt/data
tmpfs 7.8G 0 7.8G 0% /dev/shm
tmpfs 4.0M 0 4.0M 0% /sys/fs/cgroup
tmpfs 7.8G 4.0K 7.8G 1% /tmp
/dev/mmcblk0p9 120M 76K 120M 1% /mnt/boot
tmpfs 7.8G 76K 7.8G 1% /var/volatile
/dev/mmcblk0p11 677M 24K 627M 1% /mnt/sysroot/inactive
The other Jetsons that work have this configuration:
devtmpfs 3.5G 0 3.5G 0% /dev
tmpfs 3.8G 8.6M 3.8G 1% /run
/dev/disk/by-state/resin-rootA 677M 408M 219M 66% /mnt/sysroot/active
/dev/disk/by-state/resin-state 18M 409K 16M 3% /mnt/state
overlay 677M 408M 219M 66% /
/dev/mmcblk0p13 13G 6.6G 5.3G 56% /mnt/data
tmpfs 3.8G 0 3.8G 0% /dev/shm
tmpfs 3.8G 0 3.8G 0% /tmp
/dev/mmcblk0p9 120M 72K 120M 1% /mnt/boot
tmpfs 3.8G 68K 3.8G 1% /var/volatile
This is the error I’m getting in the supervisor logs:
Scheduling another update attempt in 128000ms due to failure: Error: Failed to apply state transition steps. (HTTP code 500) server error - failed to create shim task: OCI runtime create failed: runc create failed: unable to start container process: unable to apply cgroup configuration: failed to write 8043: write /sys/fs/cgroup/cpuset/system.slice/docker-81747ff07d5b4ebe70821d05e5962ae676fe9401386cb229d243b149f11658b7.scope/cgroup.procs: no space left on device: unknown Steps:["start","start","start"]
[error] at fn (/usr/src/app/dist/app.js:10:9736)
[error] at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
[error] Device state apply error Error: Failed to apply state transition steps. (HTTP code 500) server error - failed to create shim task: OCI runtime create failed: runc create failed: unable to start container process: unable to apply cgroup configuration: failed to write 8043: write /sys/fs/cgroup/cpuset/system.slice/docker-81747ff07d5b4ebe70821d05e5962ae676fe9401386cb229d243b149f11658b7.scope/cgroup.procs: no space left on device: unknown Steps:["start","start","start"]
We’ve used the latest version of jetson-flash to flash and it didn’t help. We suspect it’s definitely something to do with partitions. Any help with this will be much appreciated.
