So I’ve been trying to get the Raspberry Pi camera module working within a container for way too long. I have discovered that something is broken in the newer balenalib images.
As the most basic test, I have just been running several images and running raspistill as a test of functionality. ie:
docker run -it --privileged --entrypoint /bin/bash balenalib/raspberrypi3:latest
then from the command line issuing the command:
When using the balenalib/raspberrypi3:latest or balenalib/raspberrypi3:stretch the raspistill command just hangs and the light on the Pi camera never comes on.
Using the balenalib/raspberrypi3:jessie image, the command works as expected and the camera captures a picture.
I figured someone at Balena might be interested in this and it might save some other people a few hours of trying to figure out WTF is going on.
