Netpirate: Morse code over Pirate Radio using Raspberry Pi/BalenaFin (WIP)
NetPirate:
Is my attempt at sending ip packets using morse code over a pirate radio using a raspberry pi and a wire!
Note under active development 20220317
Last update:
20220321 - adding api server, created a kanban board for people to see project status here
20220324 - added status video
Status Update Video Demo
Status Update v2
first successful transmission of morse code over fm radio!
Software
The hardware
  • Raspberry pi (or BalenaFin :wink:))
  • Jumper wire standard size OR 75cm of wire
  • Free Time ( Really hard to source due to international chip shortage)
plug the jumper wire into pin 4 on the raspberry pi (or balenafin in my case)
where the arrow is pointing
Finished Hardware setup!
Note: im using a common jumper wire because its easy to find, but bear in mind that this will have reduced performace vs a 75 cm wire, if you really want long range (not recommended due to fcc will not like you) you can go with a longer range.
Connect your RPI (or Balena fin) to network and power
Software used rpitx which is an alterative to the now dead pifm
Download and flash the code to the pi
this tutorial assumes you aready have a account with BalenaCloud
If not signup here ------v
Go to your dashboard balena dashboard
create a fleet
name it whatever you want, and select your board for me its BalenaFin
what i put for my balena fin
what you might put for rpi 4
add a device
Select development, if you want to modify and play around with the code, if you just want to use the project select production
read the instructions
make sure the power is connected
Noob mistake: I made the mistake of thinking the USB could power the device on its own, and had to do some trouble shooting. takeaway, make sure the powerjack and the USB are plugged in at the same time.
Plug the USB cable into the PRG port, and the other end into you computer
download BalenaEtcher from here
once installed click flash
Issue I ran into, the balenafin wasn’t showing up
things to try
or try look at BalenaFin troubleshooting for more answers, if the above didn’t work
Found the issue! bad cable had to try 3 cables until i found one that worked
Not all usb cables are created equal! just because i through it was a data one didnt mean it actually was! good to know…
Now on to flashing!
Issue #2 missing drivers
Download and install this driver
note i had to unplug my fin before the driver would finish installing, but everything worked fin after that
YAY drivers installed!
Woop woop!
all the binking things means good things
Issue: my fin didnt popup :confused:
things I tired
found the issue, i didnt have the ethernate cable plugged in correctly!
from the docs
A pattern of 4-blinks on the ACT status LED indicates that the balenaFin cannot connect to a network
video of what the 4 blinks looked like
here’s what it should look like
Success! :partying_face::partying_face::partying_face::woman_dancing::women_with_bunny_ears:
Now lets add the project’s code to my pi/balena fin
Build log
I started out using F5OEO/rpitx: RF transmitter for Raspberry Pi which seemed like the way to go, it has alot of advanced features.
but I was running into alot of errors, and finally got it installed but commands run with no output! really confusing, and frustrating
Lets try another software package
PiFmAdv
Advanced Raspberry Pi FM transmitter with RDS encoding
my goal is to convert this install script into a docker file
here’s my first attempt at it.
FROM balenalib/rpi-raspbian:latest
WORKDIR /usr/src/app
RUN apt-get update && \
    apt-get upgrade -y && \
    apt-get install -y git cmake build-essential libgtk-3-dev libsdl2-dev zlib1g-dev liblua5.3-dev libgif-dev libsndfile1-dev  libsoxr-dev
RUN git clone https://github.com/Miegl/PiFmAdv.git
WORKDIR /usr/src/app/PiFmAdv/src
RUN make clean
RUN make
COPY . ./
CMD ["/bin/sh", "./pi_fm_adv"]
first error
pirateradio ./pi_fm_adv: 1: Syntax error: word unexpected (expecting ")")
attempt #2
seems promising
better…
lets see what happens when i run /bin/sh ./pi_fm_adv
darn! same issue… from google it says this might be a archeticture build issue
running ./pi_fm_adv --audio sound.wav
oops missing sound.wav file, wait no, still event if i provide correct filename
going to try privileged: true in the docker file
from google says it might help.
Failed to open /dev/mem, try checking permissions. - Forum - Raspberry Pi - element14 Community
version: '2'
services:
  pirateradio:
    build: ./pirateradio
    expose:
      - "80"
->privileged: true
lets give that a try
./pi_fm_adv --audio sound_22050.wav
OMG I THINK IT WORKING!!!
looks like i neeed to adjust the default fequency
./pi_fm_adv --audio sound_22050.wav --freq 90.6
turns out 90.6 doesnt pop up on the car radio :confused:
./pi_fm_adv --audio sound_22050.wav --freq 90.5
well its something, but its not great. im going to try another sound track from freesound.org
attempt with new sound file
./pi_fm_adv --audio sound2.wav --freq 90.7
nope. :confused: somethings up. i think its
a) wiring
b) configuration of the program
c) adjusting the gpu_freq
after some fiddling im starting to think its the gpu_freq
found this article on setting /mnt/boot/config.txt but doesnt say anything about gpu_freq Advanced boot settings - Balena Documentation
Raspberry Pi Documentation - The config.txt file
looks like i can edit the config.txt after boot.
Key: gpu_freqBALENA_HOST_CONFIG_gpu_freq
Value: 250
the fin rebooted automatically
lets try it again
SUCCESSUL AUDIO TRANSMITION!
adding api server
which sends data to the api endpoint /v1/morse to be piped to a filepipe that will send that audio data out the fm transmitter code
getting minimul api up and running
first succesfull build
turns out the flask_restx flask server doesnt allow outside hosts
should be a simple fix
from
    app.run(                debug=True, port=7878)
to
    app.run(host='0.0.0.0', debug=True, port=7878)
try number #2
nope. something else is going on
possible issues:
  • computer is on a different subnet
  • port 80/7878 are not exposed to outside world
  • maybe i dont understand app.run(host=‘0.0.0.0’…) and it doesnt actually allow outside connections
lets see if its the port issue
from this stackoverflow makes me think: hmmmmm
What is the difference between docker-compose ports vs expose - Stack Overflow
going to try this
yeah i think its a port vs expose docker issue
lets see if that worked
sucess!
sharing a filepipe for audio across two containers
the shared_pipe is a data volume shared across two containers
heres how i map the shared folder
testing to see if that the pipe works
connecting to into fm radio’s container
good news the shared folder named ‘public’ is present
creating a file to see if it shows up on both sides
loggining into the api container the file audio.wav is present! woop woop!
dockerizing a cool tool that does most of what I want. called cwwav which takes stdin text and outputs a .wav file containing the beeps and boops of morse code.
note: CW is another way of saying morse code
getting cwwave to install in docker was a royal pain.
what I did
  • change base image from balenalib/rpi-raspbian:latest to -balenalib/-python:3-stretch-run because the install script required python3
turns out the issue with my dockerized cwwav program was that it didnt have anything to do after being built. so it would eminently quit. this is not good for testing because i cant ssh into it. :confused:
so i am breaking the problem down into smaller chunks.
here i’m converting text into morse code audio file
issues installing.
these errors say to me that the data volume ‘shared_pipe’ is not mounted until when building the container
got that issue solved.
first successful manually triggered transmission of morse code over fm radio!
first automated transmition!
raw text → morse audio → fm radio!
complicated but working!
/bin/sh -c " find . -name 'morse_data.txt' | entr -r cwwav -f 400 -w 20 -o /usr/src/app/PiFmAdv/src/public/hello_world.wav /usr/src/app/PiFmAdv/src/public/morse_data.txt & /usr/src/app/PiFmAdv/src/pi_fm_adv --freq 90.7 --audio /usr/src/app/PiFmAdv/src/public/hello_world.wav"
this is two containers talking through one another using a file called morse_data.txt which is the message getting broadcast out the radio on repeat
im using a cool command called entr which watches for file changes within a directory and runs a command.
the command i run does two things.
- cwwav creates a audio file from the text within the morse_data.txt, the audio file is named hello_world.wav
- pi_fm_adv is the radio tranmitter code, and reads the file called hello_world.wav and sends it over fm radio!
pictured here is the interaction between the two docker containers. the interupted pattern is when data is written to morse_data.txt. the api will eventurally write to that file as a means to send fm morse code. cool right?
Got api working! no can update message being sent via api!
Decoded message!
still has some minor issues with encoding.
after some more investigating its not a encoding error something else is going wrong
errors and fixes:
ERROR: Could not allocate memory.
fix: just reboot your device. that fixed it for me.
I added the feature where you can configure the radio station frequency by using some environment variables (device variables in balena speak)
more information about setting env variables Variables - Balena Documentation
getting some errors when i restart the fm radio execuritable
It might be a issue where the PiFmAdv doesnt exit properily and locks the system in a weird state of limbo. the result is the fm fm radio exe doesnt restart but gives off ERROR: Could not allocate memory. error
im going to give PiFmAdv --wait 0 (instead of --wait 1 the default) a try which according to the docs
--wait specifies whether PiFmAdv should wait for the the audio pipe or terminate as soon as there is no audio. It's set to 1 by default.
I think i figured out the issue with i was running into with the ERROR: Could not allocate memory. error. there was two copies of PiFmAdv trying to run at the same time, which caused the error.
I’m experimenting with converting the start.sh file from write file read file, to pipes as recommended by @ramirogm
Also a suggestion by @ramirogm was to give local mode a shot! it was taking 5 mins to make just 1 change to populate on my device
Develop locally - Balena Documentation
note all the pushes wont be shown in balena dashboard
When trying to use localmode on windows 11 I ran into a issue.
balena scan requires admin
fix: run powershell as admin✅
Missing Bonjour service
fix: install from here Download Bonjour Print Services for Windows v2.0.2 - Apple Support
fix works!
PS local mode has livepush mode! with does heavy caching and auto reloads stuff! nice!
Challenages trying to convert my shell script that runs the translation from files to filepipes.
according to brave search .wav does not support file pipes! darn.
c - Audio file format that can be written without seeking - Stack Overflow
but this post does say that au is supported
ended up abandoning the full pipe method and im now giving a while loop a try
More updates to come!
  • Still working on getting morse to work. should be out soon!
Cheers,
- oran#
What sort of range comes from that antenna?
