Hi, Parrot Linux is debian-based so you should be able to use the etcher debian package. Ideally you should be able to use the AppImage which you can find here https://www.balena.io/etcher/#download. if not you can download the .deb file and can install it using dpkg
dpkg -i ~/path/to/balena-etcher.deb
