NanoPi R2S image
I see you have support for the NanoPi R2C, are you planning to support an image for the NanoPi R2S?
Andrew
Hello @andrew i pinged internally to the balena Devices team, if the NanoPi R2S is on the pipeline to become a supported device.
Meanwhile, did you take a look on the documentation to support a board with balena? β†’ Custom board support - Balena Documentation
And this is the balena-nanopi-r2c repository in case you know if it’s easy to support R2S boards from R2C β†’ GitHub - balena-os/balena-nanopi-r2c
Hello @andrew balenaOS running on NanoPi R2S might be available.
Let us know if it works good for you!
Hello @andrew did you have time to try the new image for NanoPi R2S?
Looking forward to get your feedback!
