Hello guys, I’ve just had issues while pushing a project using uppercase letters (BASISNOVA2R1). The log shows:
14.02.18 10:23:36 (+0000) Downloading application 'registry2.resinstaging.io/BASISNOVA2R1/e45522c30.....'
14.02.18 10:23:36 (+0000) Failed to download application 'registry2.resinstaging.io/BASISNOVA2R1/e45522c30.....' due to '(HTTP code 500) server error - invalid reference format: repository name must be lowercase '
I tried a docker pull locally and it failed:
$ docker pull registry2.resinstaging.io/BASISNOVA2R1/e45522c30030f273a3281fccb3362cb8892d2812
But when I replaced the project / image name with lowercase, it worked:
$ docker pull registry2.resinstaging.io/basisnova2r1/e45522c30.....
Using default tag: latest
latest: Pulling from basisnova2r1/e45522c30.....
(Note: image and id changed above for security reasons)
So I think there must be a bug on case-sensitive images somewhere?
