I have created an update lock on /data/resin-updates.lock in a container, however the device containers were still updated when I pushed to balenaCloud.
I fear that the update lock is not recognised, perhaps this is due to working in a multi container environment. Or could this be due to the named volume being called resin-data where in the updated instructions the volume is called balena-data.
Here is the relevant portion of the docker-compose.yml in which the volume is created.
version: '2'
volumes:
resin-data:
services:
controller:
volumes:
- 'resin-data:/data'
For completeness here is the relevant section of the instructions for multi container named data volumes.
Multi container named volumes
Additionally here is the project from which I found out how to apply update locking.
Balena Updates Lock
Hi @hpgmiskin,
The use of /data for the update lock was deprecated a long time ago, and removed in resinOS 2.x. The new location is at /tmp/resin, as per our docs: https://www.balena.io/docs/learn/deploy/release-strategy/update-locking/#location-of-the-lockfile (and soon to become /tmp/balena, but /tmp/resin will still be supported).
Could you try the new location and let us know if you hit any issues?
(btw, repos in balena-io-playground are not necessarily actively maintained, as is the case with the one you linked - always refer to our docs for up-to-date information)
Cheers!
