It seems that my balena image update failed, but current release id is updated.
So, from the outside It looks like it has been updated
I have 2 containers in balena.
After updated release version of the device, one container ran successfully, but one container couldn’t run.
And I got a such error from resin-supervisor.
Oct 30 08:27:38 DEVICE_NAME systemd[1]: Started Resin supervisor.
Oct 30 08:27:38 DEVICE_NAME resin-supervisor[3291]: Template parsing error: template: :1:8: executing "" at <.State.Health.Status>: map has no entry for key "Health"
Oct 30 08:27:39 DEVICE_NAME resin-supervisor[3291]: Container config has not changed
Oct 30 08:27:39 DEVICE_NAME resin-supervisor[3291]: time="2019-10-30T08:27:39Z" level=error msg="error waiting for container: context canceled"
Oct 30 08:27:39 DEVICE_NAME resin-supervisor[3291]: Error response from daemon: container is marked for removal and cannot be started
And I checked under /mnt/data/docker/image/aufs/imagedb/content/sha256, I found one image file a lot different from a image file the same release version which working well.
My Balena environment
# HOST OS / supervisor version
balenaOS 2.32.0+rev1 / 9.14.0
# Type
Raspberry Pi 3
Why this happens?
When I got this problem, Do I have to delete /var/lib/balena and update resin supervisor?
